Old 11-26-2008, 06:53 PM   #26
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Do you have to have correct hood
Technically speaking, the "plates" on the '67 Camaro SS hood are not the same as the Chevy II trim. Different part numbers and casting numbers, even though they seem to interchange for fit. The '68 Camaro SS cars with a 350 had the same hood trim pieces as the '67; the '68 396 cars had the four port-hole type. All the '69 SS cars all used the four port hole type trim pieces. This is according to Chevrolet parts books of that era.
The port-hole type trim had a rubber drain tube that fit into a hole in the hood to allow rain water to drain out of the recesses in the top of the hood. I watched a racer from D3 at the '71 Nationals get kicked out of tech line because he didn't have the rubber drain tubes in his hood. What's the chances of finding those at your local Chevy dealer? A local donated the ones off his street car after a four hour search.
At the same race, we got kicked out until we took our sway bar off and turned it over. Seems we had installed it upside down! Another racer from D2 with a '56 Chevy got bounced for having '55 sun visors in his car. ???? Biedencamp.
