Old 12-01-2008, 08:12 PM   #1
Lyn Smith
Liked 994 Times in 200 Posts
Default 12 bolt bearing cap
Ive got a 12 bolt missing a cap. Who makes a replacement cap?
Lyn Smith is online now   Reply With Quote
Old 12-01-2008, 08:22 PM   #2
Liked 1,880 Times in 422 Posts
Default Re: 12 bolt bearing cap
Mark Williams makes steel billet caps.
Old 12-02-2008, 12:27 PM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
www.tomsdifferentials.com
Easy self install....used only on the driver side usually.
Comes with upgraded fasteners for the passenger cap, driver side must be drilled and tapped for 1/2" fastener, provided.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 12-04-2008, 02:02 AM   #4
NovaMan
NovaMan's Avatar
Why doesn't that one require milling like everybody else's?
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 12-04-2008, 11:35 AM   #5
Dave Goob Cook
Dunno..
It requires "fitting", but nothing more than what can be done with a file.
I've had mine for 12 years.
Dave Cook
NHRA N375
Old 03-07-2009, 03:52 AM   #6
NovaMan
NovaMan's Avatar
I was just thinking about this again, and I wondered why I've never seen any bearing cap studs?
~Pete
1970 Nova
Old 03-08-2009, 09:29 AM   #7
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
i found if you tap the existing threaded holes deeper with the 2nd of a three tap set (not the starter taper tap and not the bottoming tap) so that the tap end goes flush with the back side of the opening you can still bottom out a set of studs with over an inch of thread holding. even through the studs bottom out i still used blue locktite.
Ian
Ian Hill is offline   Reply With Quote
