John, I just went through that this summer and saw the same thing you did. Nothing. On top of that I cleaned the right side axle spines out of the spool on the starting line 1st round at the Mid Souths at Memphis. Only good light I've had all year too. Byron Latino didn't mind it too much.
![]() When I tore it down, it also had a tight spot when turning it through, the ring gear flange had developed .007" run-out. It was straight when installed. Don't need any more of that crap.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 12-05-2008 at 08:31 AM. |
Liked 106 Times in 23 Posts
I couldn't agree more. IMO, the closer to the center driveline the less 'noticeable' difference. We have not seen an improvement in E.T. One of our stockers had a 12 bolt Posi with stock axles and we tricked it out with the latest and greatest (and expensive, too). It might be worth something when combined with many other factors. It could simply be more reliable.
We do it because everyone else does it and who wants to give up a questionable .005! EMS |
Liked 332 Times in 180 Posts
I'm not promoting it as a surefire way to lose a TENTH but if used in combination with many other "tricks" it usually does add up to a reduction in overall ET--Isn't that what its all about anyway??? you lose a hun/thou here and a hun/thou there add it all up and pretty soon you have consistently lost several hun/thou in you overall ET Comp 387
The lower your HP/Torque is, and the higher your starting line gear ratio and operating RPM is, the more difference it would make, and almost never would you see much of a gain in a torque converter equipped car.
Moment of inertia is the critical factor
"Despite the high cost of living, it remains popular." Dave Cook NHRA N375 |
At Memphis when I killed mine, Jerry Haas walked over to my trailer when I got back (I almost fainted) and said he was standing up there when it happened. He asked what size axles I had. I told him 35 spline. He said it shouldn't be an axle, then asked if I had an aluminium spool, I said yes. He told me it was the axle splines in the spool that gave up, and that he no longer use them in anything, that he never saw any gains, only a source of problems. He asked "What did you save, 5lbs?" I said exactly five. He said "Save your money next time." I'll take him at his word.
Didn't have nerve to ask for an autograph. ![]()
Ed Wright 4156 SS/JA |
Liked 801 Times in 338 Posts
We took 41 pounds of rotating weight off our car with disk brakes a few years ago. Sure does stop a lot better but it does not go any faster.
Bill |
The math is not all that simple buy you can work out exactly how any particular part can/will affect the acceleration of your car. Hear is a couple of links briefly explaining some of the math involved;
http://hyperphysics.phy-astr.gsu.edu/Hbase/rke.html http://www.ac.wwu.edu/~vawter/Physic...FormsofME.html Where it gets complicated is that to get a truly accurate picture of how a part will affect the acceleration of your car (to accurately calculate the energy or work required to accelerate the part to a certain RPM) you don’t need to know its weight you need to know the moment of inertia. Also what I talk about below is only part of the bigger picture you have the whole car to accelerate not just the rotational speed of the part. To put it all into laymen’s terms not all light parts are created equal. I will use light wheels as an example; two different 10 pound wheels can take significantly different amounts of energy to accelerate through the ¼ mile; Brand X with a heavier center and super light outer rim will take much less energy to accelerate than brand Y with a super light center and heavier outer rim. Again keeping it simple and not getting into center of mass and moment of inertia calculations; Speed = 2*pi*r and kinetic energy = ½ *velocity^2 So comparing the kinetic energy of two identical weights but one twice as far out from the center as the other both rotating at the same RPM the one twice as far out will have 4 times the energy or will have taken 4 times the energy to get it up to that speed. So the benefit of lightening rotating parts diminishes the closer you get to the rotational center. Gun drilling axles; almost no benefit, only unsprung weight Aluminum spool is less effective than the same weight savings by turning the outside of the ring gear. AND all light wheels are not created equally. Most people see ET improvement with light wheels because there is such a significant savings in rotational weight compared to any other thing you can do. Also what this all shows is that rotational weight savings prior to the rear end is very important. Taking rotational weight out of your transmission and engine is far more beneficial as it has to wind up to 5 or 6 times the RPM of your rear tires. I think the Yak touched on this in another thread talking about the two different diameter clutches and flywheels. Just because two parts weigh the same does not mean they accelerate the same.
Bill Edgeworth 6471 STK |
