Liked 26 Times in 13 Posts
![]() ![]() ![]() ![]() ![]() You gotta be kidding. You have a small block that is good for well over 8000 RPM and your are using a 5000 RPM converter and a 3.73 gear????? WAY wrong. I would expect to see a converter in the 6000 range and a 5.83 to 6.00 rear gear. What MPH did you go on the few passes you did make? The MPH will tell you if you have enough HP. If you are running 122+ MPH, you have pleny of power, you just aren't getting that thing moving off the line. A 60' of 1.72 speaks volumes. You should be under 1.40 to go mid 10's.
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 3 Times in 2 Posts
Best MPH was 119, consistantly 99/101 in the 1/8th.
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Liked 163 Times in 53 Posts
if this is the mph you are running then your car is running out of steam, my street car runs 124mph in the 1/4 in 99mph in the 1/8. This is a n/a 331 with a 5speed. You need more gear under this car....ala 4.30-4.56
I agree, your running out of HP on the top end. Even so, if you had a respectable 60 in the low 1.40's you should be running 11.0's with what you have. Your not going to get there without a lot more gear.
I don't see where a glide is gonna help. There is no reason on earth why you shouldn't be able to get your C4 to live long and work great. There are c4's behind 750+ HP big blocks that do just fine.
What gear are you guys running in your Auto SS cars? I have had people tell me the 3.73's were great for what i want to run, and yet others say I need at least a 4.30. I know most SS cars make the absolute most out of what they are allowed.
Liked 32 Times in 14 Posts
The PG will absoluteley kill the ets. I cant believe someone told you 3.73's were the way to go. With a 28" tire I would recommend either a 4.56 or 4.86 depending on how high you want to spin it. The other thing that draws a red flag for me is the mph you have seen and I would MAKE SURE the valve springs are up to snuff. Just because you dont hear a audible "valve float" doesnt mean they arent out of control. As others have said the dyno may help but if it's still in the car I would try the new rear gears first WITH a C4. 3.73's had to be killing that poor thing. Hope this helps.
Jay
Jay Roeder facebook.com/racefuelsales Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer |
