Old 12-25-2008, 01:54 PM   #12
Jeff Lee
Jeff Lee's Avatar
Default Re: Older Superstock GT cars with scoops
Originally Posted by Shawn Blair View Post
One good reason for the scoop would be carb clearance, this would be a good thing if running the 1962 343horse 383 combo with a tunnel ram. I'm still waiting to see that one! It would have to be fast with those two carbs.
Yes, open or not the key is carb and manifold clearance. A budget racer could take a 380 2x4 carb and use your basic Weind cast aluminum tunnel ram under one of these scoops. A lot less money than a sheet-metal tunnel ram; and possibly more effective. I would think the tall scoop would open up some new technology for the 6-pack 340/440 intake manifolds as well.
Looks like Teuton and Hale have the open scoop issue worked out with NHRA. Jeff, are you considering the 383/343? I guess a 440/375/350 engine would also be a killer. Guess you could even run a Weind/Edelbrock single 4bbl tunnel ram in that car, on any mopar engine.
Jeff Lee 7494 D/S '70 AMX
