I am getting ready to purchase new front rubber and i figured i would see what most of you guys out there were using as far as size goes. Also what the reason is for the size choice. any thoughts would be helpful and thanks for any replies.
Dion Hildebrandt 6009 STK H/SA |
Liked 19 Times in 7 Posts
Moroso Drag Specials if you can fit them. Not the lightest tire but look good.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Liked 4 Times in 2 Posts
How about a smokeless unit?
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
Liked 138 Times in 51 Posts
I choose front tire size based on the reaction times I get when staged "comfortably". You can fine-tune RT's with air pressure, staging rpm & bumping, but the diameter gets me in the ballpark, as long as you have enough fender and ride height clearance. Taller for more rollout, slightly faster ET's and slower reaction times and, of course, the opposite for shorter tires.
As for brand, I just match the 28" fronts to what I run on the back, Hoosiers.
LOCOMOTION Racing |
thanks Myron i was leaning towards a 28 or 29 tall the car seems to redlight easy. i think the current tire is 26 tall.
Dion,
I have a pair of new Firestone 28" front drag tires that I would sell for $100 plus shipping. Never been used. bobbyz@ioa.com (828) 891-2522
Bobby & Norene Zlatkin L/SA |
Liked 529 Times in 36 Posts
Hi Dion,
I use Moroso on both of my Dusters with good luck. I use 28" on the stocker and 26" on the no box both seem to last well. Darcy |
Liked 427 Times in 97 Posts
Dion, I use 7.60 x 15 Moroso Drag Specials on the front of my 70 Chevelle.
It has trick springs with a full coil removed. Good Luck Greg |
Liked 20 Times in 15 Posts
I use the 7.10 x 15" Moroso Drag Specials . They weigh about 12.5 lbs & clear my headers nicely. The 7.60's are a bit too tall & rub on the way down on one of the tubes. With the "Flys" they come in at 21.6 lbs.
Liked 5 Times in 3 Posts
I run the 27.5 M/T they work great. I had the Moroso DS 2 on my last car & they didn't last to long?
