Old 01-06-2009, 11:10 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
Default Re: Runner Volumes
Hey Daran. Jay Slane had similar results with a set of 441 heads that he is working on. All of the small block heads that I have CC'd before porting have come up about 6 CC's smaller than the SS limit. I am not sure how that compares with big block or other brands. NHRA will probably just allow some mild porting and epoxy in the intake and welded exhaust like SS. They couldnt control the head rule in super stock so they changed the rules. They will probably do the same for stock. Then a good set of heads will cost 7500.00 but you wont have to worry about passing teardown. As long as the valve size is correct and the CC's are right you will pass.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-06-2009, 11:14 AM   #2
Woodro Josey
Liked 3 Times in 1 Post
Daran, FYI, there are 2 different castings in the 441's one type is bigger on intake runners than the other!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 01-06-2009, 11:38 AM   #3
Lyn Smith
Liked 963 Times in 193 Posts
Why dont they just add 2 or 3 percent to all the SS volumes,and use that for both the STK and SS numbers? They should only have one list.Will be alot less confusing when you race a stocker in SS.
Lyn Smith is online now   Reply With Quote
Old 01-06-2009, 01:05 PM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Re: Runner Volumes
I have to agree with Lyn...their are alot of guys that run both S & SS with the same car. I also have a question on the head volumes...what about the cars that have NO #'s like our 6cyl nova? I don't see any #'s for a 230!
Old 01-06-2009, 06:01 PM   #5
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
DARAN:
161 CC is the spec for the intake side. My intakes were safely under the spec as well.
It's the exhaust side that is way too close for comfort. Same result now on 3 sets.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 01-06-2009, 06:56 PM   #6
SPS
Liked 3 Times in 2 Posts
Who's to say the numbers used for Super Stock are really "right" anyway.
I'm sure no scientific methods were ever used to arrive at the magic numbers we have to use.
As Woodro says , there are different castings made at different foundries that definately have different volumes when made.
I for one like Lyn's idea to add 2 or 3 percent and get on with it.
FJ
SPS is offline   Reply With Quote
Old 01-07-2009, 02:42 AM   #7
Adger Smith
Liked 880 Times in 311 Posts
Just a little insight to the production of heads. My buddies at Brodix tell me that a fresh core box will produce heads that are on spec. I assume that means port location & cc's because they say at the end of a production run the core boxes are showing wear & the port volumn will be smaller than designed. I would think the same applies to any automaker produced heads. The Design/R&D guys at Brodix have used the term "Filed" core when talking about producing a bigger runner head. Hey, the pattern maker has a bad day on Monday & the molds are off spec. He sobers up by Wed and is feeling good so he makes some molds over spec. At that time of original design & production little did they know that the quality of their work & a few CC's would mean so much to racers.
Adger Smith (Former SS)
