Old 01-06-2009, 04:49 PM   #1
Ron Miller
Liked 13 Times in 7 Posts
Default Re: shifter in factory console, 3rd Gen Camaro/Firebird
I have a B & M Pro Stick mounted in mine with a no cover of course with a SHIF NOIDE mounted behind the shifter. The Pro Stick is almost identical to the 1/4 stick. So mounting will be the same. You will have to make a lower bracket to mount the 1/4 stick shifter body on top of the trans tunnel sheet metal. This all will fit in the center console. I maid my own top cover out of aluminum, painted it with the SEM plastic satin black paint. I also had to make a extension for the reverse lever. Its doable if you all ready have a 1/4 stick. Its easier that it sounds to mount it. Mock it up first and you will see what it takes. Send me a e-mail rmiller249@comcast.net. I can take a picture of my set up for you and send it back.
Ron Miller 92Camaro GT/DA 3287
Brownstown, Mi
Ron Miller is offline   Reply With Quote
Old 01-06-2009, 05:26 PM   #2
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
I have seen a lot of guys fit a quarter stick in the factory console in 3rd Gens. Here are 2 pictures of one in our 4th Gen.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 01-06-2009, 06:05 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Lee,
Thanks, looks good.
Also, what is the gauge near the right kick panel?
Larry
Larry Woodfin 471W
Old 01-06-2009, 09:18 PM   #4
Jim Carter
Liked 19 Times in 3 Posts
Smile Re: shifter in factory console, 3rd Gen Camaro/Firebird
I have a question that is somewhat related:
How and where are most racers locating their neutral safety switch for trouble-free performance with a Quarter Stick??
Thanks.
JC
Jim Carter is offline   Reply With Quote
Old 01-06-2009, 09:40 PM   #5
Ron Miller
I thought I would add my pictures that I sent to Larry, but I can not. Do you have to have special privileges. So if any one can help let me know.
Thanks,
Brownstown, Mi
Old 01-06-2009, 09:41 PM   #6
Doug Blackley
Doug Blackley's Avatar
Both the Turbo Action SCS and Hurst Quarter stick will work with the 3rd gen console. Minor mods to the automatic bezel finish it nicely.
Doug Blackley 1697 STK
Old 01-06-2009, 09:53 PM   #7
LNorton
LNorton's Avatar
Originally Posted by Dragsinger View Post
Lee,
Thanks, looks good.
Larry
Thanks Larry!
The gauge is a water temp gauge.
Thanks.
JC
I use the NSS that came with the shifter. It is located within the assembly. Has been flawless for us!
RacerTees.com
Old 01-07-2009, 12:46 AM   #8
Jim Carter
Thumbs up Re: shifter in factory console, 3rd Gen Camaro/Firebird
Originally Posted by LNorton View Post
Thanks Larry!
Lee:
Thanks for that timely info. I did a little digging and discovered that Hurst has a retofit kit for the internally mounted NSS you are using. The newer shifters come with it built in. My older shifter has an external switch that is beginning to give me trouble.
I have now ordered the new kit. ($26.00)
Thanks again!!
JimmieC
