Old 11-02-2009, 03:19 PM   #11
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: Lencos in SS
Originally Posted by Travis Gusso View Post
Jeff-
On a clutchless 5-speed (and I assume 4-speed) the only gear that it will lock in is 5th - meaning you don't have to hold (the shifter) it in gear when you are off the gas. It will come out of all other gears when you lift off the gas unless you physically hold the shifter in that gear. This is how they check for clutchless tranny's, put the car in any gear but 5th and rock the car back in forth. If it pops out of gear it is obviously a clutchless unit. -tg
Travis
I driven a clutchless tranny before in a friend of mine's bracket car, and in the pits, if you let off the gas, the trans popped out of gear. You are not suppose to hold the trans in gear! If the trans pops out of gear, than you have to come to a complete stop and start back over again shifting! I was told that by g-force yrrrrrrrrrrrrsss ago.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
