Liked 121 Times in 11 Posts
Does the weight of a car change the stall of the converter? For example if a converter stallls at 4800 in a 3400 lbs car and you remove 200lbs does it change or stay the same?
Joe DeMarzo 1317 STK |
Liked 359 Times in 103 Posts
The stall of the converter has to do with the horsepower supplied by the engine to the converter and nothing to do with the weight of the car until the car is launched when the converter starts to do its work.
My 2 Cents Rick Cates |
Yes, but even though the flash rpm would stay the same, once the car is moving the converter would "act" tighter in the lighter car.
Sho 'nuff!
Ed Wright 4156 SS/JA |
Liked 460 Times in 91 Posts
x2
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 880 Times in 311 Posts
Billy, Well said!
It will also change the way it works if you change gear ratios. A deeper low gear will make it act like it is tighter.
Adger Smith (Former SS) |
Liked 6 Times in 5 Posts
Is this because the weight of the car affects the 'force' the converter 'sees'? Or that if the car is heavier, the converter is 'forced' to work harder and will therefore be looser?
The converter would be loaded for a slightly longer period of time in the heavier car. (200 lbs heavier, same car)
#9 | |
A good running Powerglide car does so, in spite of having such a high 1st gear ratio, because the converter is forced to "work harder". As another example pertaining to weight; A street and strip car with a high stall converter,cruising along on the freeway, comes to a hill or rise in the road. The effect of the hill is that the car thinks it's "heavier" and the RPMs will rise, while maintaining the same MPH. You've got to remember,unless it's got a lock up clutch it it, it is a fluid coupling
#10 | |
Liked 244 Times in 26 Posts
At least in our cars, the engine goes past the torque peak then settles down at a lower torque value for flash/stall. And keeping everything equal with gearing and weight, in good air it will flash at a higher rpm with increased torque. |
