Old 09-10-2011, 10:17 PM   #7
Greg Reimer 7376
Liked 719 Times in 220 Posts
Default Re: Stocker block SBC
Originally Posted by Alan Roehrich View Post
Danny, the Little M Sportsman block and the 31161111 SHP are the two accepted Dart blocks.
Some Dart blocks do require a taller lifter if you are using roller lifters, as the lifter bosses are taller. The SHP block is listed as having the necessary dimensions and bosses to use OEM roller lifters and camshafts.
I've used and sold both. The biggest thing is knowing how to hone them. You also often have to kiss both the lifter bores and the main bores to suit your needs.
I gotta question. Will the 31161111SHP blocks legal with a 327?While a 327 and a 350 share bore sizes and almost everything else,the 327's were all 2 bolt main.Also, do these come with bushed lifter bores? The crank I use is the large journal steel forging. I have a few of these, so that's not a problem. Just thought I'd ask.
