Old 12-08-2012, 10:43 AM   #251
Greg Hill
Liked 279 Times in 68 Posts
Default Re: GM Releases 2013 bogus HP ratings at PRI show
Originally Posted by boster View Post
Andrew buy Ford Racing part and all your problems will be solved . You will get the extra CC"s you request
Merry Christmas
Bo, they won't fit on our motors. How about a set pf GM fast burn heads, a 511 lift roller cam, a victor manifold, a 1050 dominator, amd a 15 hp reduction. I would be glad to run against these bogus crate motor cars then.
Greg Hill 4171 STK
Old 12-08-2012, 11:42 AM   #252
RJ Sledge
Liked 288 Times in 90 Posts
Greg answer a question for me please. What did you do to get 35hp taken off a combination? Or was NHRA just feeling benevolent?? I'm serious and was just wondering. Maybe I could get you and your son to do some lobbying with NHRA for me.
Merry Christmas
RJ
RJ Sledge is offline   Reply With Quote
Old 12-08-2012, 11:46 AM   #253
GUMP
Liked 2,354 Times in 554 Posts
I have asked several of these "rock slingers" the same question over the last few years. I am still eagerly awaiting the answer............
Old 12-08-2012, 12:13 PM   #254
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
My combination has been rated at 325 for a long time, we didn't ask for HP off. Does anyone really think a 350 sbc from 1970 would be competitive at 360 hp? I don't know who asked for the HP to be taken off, but they don't run the combination now, and I don't know of another one besides the one Tommy Gaynor has that's been very fast over the time I've been around the race track. It's clearly not a bad combination, but it's also the highest rated carbureted small block chevy in the guide (the same motor in a Corvette is 5 more, but stick only).
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 12-08-2012, 12:38 PM   #255
boster
boster's Avatar
Talking Re: GM Releases 2013 bogus HP ratings at PRI show
If it were up to me I would give the older car performance enhancement part or weight reductions starting today .
To me this is the easiest way to fix the problem and make everyone happy in the most cost effective way .
Most guys redo their stuff on a yearly basis , bigger cam's, more cc's, bigger valves, higher compression , bigger carbs is easy stuff to do .
Racers should start a petition to NHRA to make some simple changes for the older car, then AHFS will sort out the mistakes in a few years
Merry Christmas
Bo Kenney
boster is offline   Reply With Quote
Old 12-08-2012, 12:42 PM   #256
KRatcliff
Liked 534 Times in 143 Posts
It looks to me the easiest and simplest solution is to put the factory's experiments into the FX class. No reason to make changes to so many when it is so few that are sticking out.
The FX classes are really cool and self explanatory to fans and racers alike. It shouldn't be all that complicated.
KRatcliff is offline   Reply With Quote
Old 12-08-2012, 01:18 PM   #257
Chad Rhodes
and the only investment the owners of the new cars have to make is some new vinyl for class designation. Tell ya what, I'll make it even easier. I have a vinyl cutter, I'll make them for them for free.
Chad Rhodes 2113 I/SA
Old 12-08-2012, 01:20 PM   #258
RJ Sledge
Sorry Bo, I have too disagree, and I am currently building a 2010 Mustang with the 352 combo.
I guess I lean with Kyle, not sure how it could be done, as the Factories are bringing out New Improved Products every year now. Maybe have them run (F/X, Factory Hot Rod or whatever) for a 3 year tour and then be absorbed into Stock/SuperStock and let the Ahfs go to WORK (sic) from there.
I still plan on running my old car until I find a buyer for it.
Running a Bogus Hp combo car Heads Up is unfair and down right stealing to me regardless if it were a NEW Combo or an Old Combo My old car has had 1 hp taken off of it from the Factory Rating and although I would like to have an extra 15 or 20 HP taken off I know that it ain't gonna happen!! But I can always wish!!
RJ
Go Irish!! (I took the 10 points)
Old 12-08-2012, 01:23 PM   #259
Chad Rhodes
Actually the 69 LT-1 350 corvette is rated at 370 in stock, WAY over factored, but just thought I'd point it out
Old 12-08-2012, 01:29 PM   #260
KRatcliff
Without being an insider, I can only surmise why they don't do the FX. My best guess is that the factories would rather see them compete against combos that don't have a chance so it would help sales of new cars.
The FX class would be a financial disaster for the new car owners. This type of racing is already expensive enough. The entry cost of the new cars is pretty steep. Staying at the top of the heap is even more expensive.
Putting all of these cars in FX would pit them against each other and make Comp look entry level.
