Old 09-21-2013, 07:36 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Intermittent no start condition
Originally Posted by ss3011 View Post
Thanks for the info John. Now we know that none of the trigger electronics in the Opti-Spark have anything to do with your no start condition. It is so hard to track down intermittent problems. Since you have spark it is a good bet that you have a connection or wiring problem. Usually ECU's either work or they don't. Have you tried disconnecting the main injector connector and reconnecting it ? Most all the terminals are crimp connectors. If you know which wires are the power leads, then when you have a no-start condition leave the power on and probe to see if indeed you have the 12v power to the injectors. The ECU provides the ground to pulse the injectors. If you don't have it set up for sequential , which I don't think you do, because the Opti-Spark trigger is not hooked up. Then your system fires 4 injectors at once. Everytime the ECU sees 4 pulses from the crank trigger it fires a set of 4 injectors, usually bank to bank. It doesn't know when, since it has no particular cylinder reference, just every 4 pulses. Your ignition works, so the ECU is getting the pulses. If the injectors aren't firing then check the simple things first, like the connector connections, 12V supply to the harness, etc. You will figure it out, that DFI system is very reliable.
I agree 100% with this post.....and this advice is spot on....
Rich Biebel
S/C 1479
Stock 147R
Old 09-22-2013, 10:53 AM   #2
John Nechiporchik
Liked 13 Times in 7 Posts
SS3011 and Rich,
This morning I read your post again and went back to the drawing board. I have the wire pin out list and started looking for the power feed circuits(+12v) to the ECU. I found a power feed that had an in-line fuse in a Packard fuse holder with a cover on it. I looked at this previously and thought it was a connector....not a fuse. Well, I popped the cover and found a blown 30 amp fuse. Replaced the fuse, car fired right up. I started it 7 times and each time it fired up.
Recall this started as an intermittent problem, then a full blown no start. So, the fuse got the car running again. I'm hopeful that running the ground back to the negative battery lug solves the intermittent issue. I will continue to start it randomly throughout the day and validate that the problem is solved.
I will also replace the coil as the MSD 8261 seems to have a history of problems.
I hope this is the last I need to post on this issue.
I want to say "Thank You" to all of the help you guys have given me as we walked through this thing.
I learned more about this electronic fuel injection system in a week then I thought I would ever learn!!!
John Nechiporchik is offline   Reply With Quote
