03-26-2015, 06:29 PM
#26
Re: If you could run a National event without the AHFS in pl
Originally Posted by Tony Corley
Ok, I'm still lost, because I fail to see how it affects the outcome of the race. If all of the FSS cars are not affected, and the older cars are not having to run heads up against them, what difference does it make?
In other words, the way I understand it, is the FSS cars can run all out, without penalty against each other. But when they move into regular. eliminations, doesn't it once again, just become a bracket race? At that point I don't see any disadvantage for the older cars.
Again, I really don't understand what the issue is, unless it was a heads up race with no break out in affect. Otherwise, why does it matter?
I actually see it as an advantage for the older cars, because the new combos will be forced to show their hand much sooner and run all out, instead of hiding behind a soft index.
Tony - What you are not seeing is the agendas of some that are being clouded by all the testosarone flying around the fact that they want to qualify higher than everyone else ......Hope this clears things up for you.And you are right - once first round begins its a bracket race for the most part .
