Liked 20 Times in 14 Posts
Thanks. The trailer had regular plates just used truck with dealer plates. In this situation would the driver be subject to d.o.t laws like a log book etc.?
Liked 19 Times in 6 Posts
I tow all over in MI with a 3/4 ton and 28ft enclosed. Never had a problem. I don't have any advertising either though. I've also never stopped at a set of scales.
Trying to find DOT info is muddy at best. It's supposed to be 26,001 and above for license, but I do hear of local landscapers getting checked for DOT numbers when they are above 10,000 because they are a business with hired drivers often. Then factor in the retirees with MH and 1-tons right near 30k and they aren't required to do anything additional. In MI if your setup looks decent and your not driving crazy I doubt the DOT ever bothers. Last edited by ironside68; 03-07-2016 at 01:58 PM. |
You are not allowed to tow in Michigan with dealer plates. The police will not overlook this. As for the cdl, I'm not certain, but if your rig is 26,001 lbs or greater, I would consider getting one.
Liked 100 Times in 51 Posts
I found this online.
Michigan Any Michigan resident who intends to operate the following commercial vehicles is required to have a commercial driver license: Single Vehicles - Having a gross vehicle weight rating (GVWR)* of 26,001 pounds or more. Combination Vehicles - Towing a trailer or other vehicles with a GVWR of 10,001 pounds or more when the gross combination weight rating (GCWR)** is 26,001 pounds or more. Vehicles: Designed to transport 16 or more people (including the driver) Carrying hazardous materials in amounts requiring placarding |
[QUOTE=voltdr;497631]I found this online.
Michigan Any Michigan resident who intends to operate the following commercial vehicles is required to have a commercial driver license: Single Vehicles - Having a gross vehicle weight rating (GVWR)* of 26,001 pounds or more. Combination Vehicles - Towing a trailer or other vehicles with a GVWR of 10,001 pounds or more when the gross combination weight rating (GCWR)** is 26,001 pounds or more Local police is saying the 10,001pounds includes the truck used to tow trailer!! This can't be right??? |
#7 | |
Liked 68 Times in 41 Posts
[quote=junior barns;497691]
the key word here is commercial vehicles.A dealer plate is commercial.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
