Old 06-07-2016, 05:59 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: NHRA Battery Rules
Originally Posted by Terry Cain View Post
Well, since it was brought up I'll add something to the mix. 68 and up Corvettes have the original battery located behind the drivers seat inside the interior less than 12 inches from the tunnel where the driveshaft is rotating. Think about that.
Very bad deal there and I know first hand how bad.
I pulled an engine on a '69 Vette at home for a customer and we rebuilt the engine at the shop I worked at. An LT-1 350.
Reinstalled fresh engine and recall tugging on positive battery cable as it was very tight going on the starter solenoid.
Got engine running and all was ok after struggling with a few typical Corvette issues....
Started to drive it to work....a 10 mile ride....Heard some odd crackling noises and saw some smoke at the shifter console....realized something was burning up electrically under the console......pulled over and was able to push the console out of the way and stop the dead shorted battery cable that had been whacked repeatedly by the u-joint and had shorted out....console luckily was loose...
Car was dead in water.....parking brake did not work.....nosed it into a curb on a down hill street.....more to the story but that was plenty already...
I never had anything but bad things happen anytime I worked on a Corvette.....and I have a much worse story....!!!
Rich Biebel
S/C 1479
Stock 147R
Old 06-07-2016, 09:09 PM   #2
George Mirza
The original reason for the second battery came about when Nhra stopped the practice of cooling the cars in the staging lanes with cold water. They allowed a second battery to run extra fans and water pump drives to make up for the cooling. But over time the use of the second battery became blurred and now is used as part of the electrical system. Problem is in a stocker you need a working alternator which makes the ability of the master cutoff switch to kill the car a complicated issue. This is one of those gray areas where every tech guy and division has their on take on it. The master switch on my car has never shut the car off, only the accesories hooked to it. I always started and ran my car with the front battery and alternator. The rear battery was used for cooling only and not tied into the charging system.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
Old 06-09-2016, 10:31 AM   #3
Run to Rund
Liked 54 Times in 27 Posts
You can shut off the engine with the cut off switch by wiring the MSD trigger through it. I also run a 4 gauge alternator hot wire, back to the switch.
Old 01-22-2017, 10:19 AM   #4
Frank Castros
My Pet Peeve,
The N.H.R.A. doesn't allow relocating batteries to the trunk in Stock Eliminator but allows aftermarket blocks and heads, roller rockers, solid lifters, any duration camshafts, aluminum radiators, electric water pumps and fans, aftermarket oil pans, exotic transmissions, aftermarket disc brakes, wheelie bars, fuel cells, Kirkey seats, hood scoops on cars that didn't come with one, bogus combinations and Factory Super Cars that don't belong in Stock Eliminator.
My Two Cents on a rainy Sunday morning in the Low Country.
Old 02-03-2017, 04:59 PM   #5
Rick Kolber
Liked 32 Times in 13 Posts
[QUOTE=Frank Castros;524802]My Pet Peeve,
Well said on all the above!
Rick Kolber is offline   Reply With Quote
