#11 | |
Liked 23 Times in 13 Posts
Frank Bialas 1570 STK |
#12 |
Liked 239 Times in 114 Posts
I was able to use a CSR shield on by 67 Belvedere but had to do two things . To fit the shield to the trans , I had to cut quite a few bosses off the trans case . The shield fits like a glove , So I have it on the trans before I install it into the car . I have to let the engine tilt down in the back or I can't get at the top two bolts . I did trim back the flange where the trans tunnel to the firewall hangs down , then after the trans is bolted up to the engine , I jack it into place and install the trans crossmember . Its tight but it all fits . I wished that CSR would clearance the shield for the ProTrans band adjustment , and change where the buckle is for the strap , because its is wedged up in the trans tunnel , just move it down a few inches . Glad they are finally making the shields again , they were out of stock for almost a year .
#13 |
Suggest going back to Junior Stock
#14 | |
#15 |
Liked 10 Times in 6 Posts
#16 |
Liked 31 Times in 10 Posts
Removable tunnel would be nice.
Michael Brand II 505B - F/SA |
#17 |
Liked 231 Times in 107 Posts
I asked the other day about just putting shield on inside of car "on top" of tunnel since your MAIN objective is protection for driver and didn't get an answer OR IS IT PROTECTION OF SURFACE from oil downs?
#18 | |
#19 |
Liked 70 Times in 29 Posts
Is this rule because there are so many transmission explosions in stock?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#20 | |
Liked 1,349 Times in 412 Posts
Darn blankets get super dirty. Drag your straps throw the water box for a little extra cooling. |
