Old 09-02-2022, 06:02 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default Mopar parts
1-Pair 308 stock eliminator heads, fresh valve grind, new valves
66 cc, 1.88 intake valves bolt on and go. $2900.00
1-pr small block adjustable rocker arm assembly by Rockerarm
Specialties, thick shafts, complete $200.00 -sold
1-pr small block thick rocker shafts. $125.00 -sold
1-New set Barton tool steel uncoated solid lifters $400.00 -sold
ProTrans manual reverse valve body,fits 904 or 727 transmission $250.00
Turbo Action manual reverse valve body 904-727 $200.00
1-RB tack drive distributor Mopar perfomance $150.00
1-1964 -426 HEMI original 4bbl aluminum manifold $250.00 -sold
1-1964 - 426 Hemi original 4bbl Magnesium manifold $475.00 -sold
1-1963 # 286 Max Wedge head, 1 ONLY $500.00
1-EARLY W-2 econo head $200.00
1-used set B&E body .840 dia. Mopar Performance race torsion bars $300.00 -sold
1-New set B&E body .840 dia Mopar Performance race torsion bars $475.00 -sold
! PRO TRANS 727race trans, all aluminum inside, 2.45 ratio, no trans brake $4500.00
! complete 440 -6pk pan to manifold stock elminator engine, fresh 0 runs. $15000.00
Lots of other parts, wheels etc. complete machine shop for sale.760-630-9094
Gregg Luneack is offline   Reply With Quote
Old 09-03-2022, 03:35 AM   #2
GTX JOHN
Liked 2,469 Times in 695 Posts
Default Re: Mopar parts
I will take the small block rocker arms and shafts!
John Irving
741 Stock
741 Super Stock
Old 09-03-2022, 10:09 AM   #3
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
I'll take the torsion bars. 33O-212-53O7.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 09-03-2022, 09:43 PM   #4
Gregg Luneack
sale pending
Old 09-04-2022, 01:50 AM   #5
Scott Loge
Liked 145 Times in 32 Posts
Gregg
When you have a moment could you call
Mike Loge 925-584-8402 I'm interested in a couple items.
Thank you!!
Scott
Scott Loge is offline   Reply With Quote
Old 09-04-2022, 03:19 PM   #6
GTX JOHN
If the RB Dist. is mag pickup (Not Points) = I will take it.
John Irving
741 Stock
741 Super Stock
Old 11-07-2022, 09:51 PM   #7
Big Ed
Gregg was just told about this. do you still have the pro-trans trans. ?
Big Ed is offline   Reply With Quote
