Liked 84 Times in 21 Posts
Hoosier has this tire listed as NEW. It’s a 9x30 drag radial but also listed as 9.9” tread width and a C30 compound. Is this a Legal stocker tire? It may have the 9x30 imprinted on the sidewall But???? And where does that C30 compound fit in the spectrum? If you follow the transition of their compound scale is that tread rock hard? What is the target application of this tire?
Liked 240 Times in 112 Posts
I've only used an M/T Radial
BUT G/Y has a radial that measures just about Identically. The rulebook says "may not exceed 10" wide regardless of wear".
Dave Noll, EF/S ,?/SA 6526 |
#3 | |
Liked 358 Times in 83 Posts
Liked 7 Times in 4 Posts
This tire is Stock Eliminator approved. It has been run on Factory Showdown cars of Chris Holbrook and Doug Hamp. The compound I am told has more grip then the C06 but is tougher. Hope this helps
Thank you very much. That is what I was interested in hearing.
