Old 04-18-2024, 10:27 PM   #14
Bob Sherwood
Liked 388 Times in 60 Posts
Default Re: 402 stocker engine
Originally Posted by Alan Roehrich View Post
Not having smoke from the headers simply means there's not a lot of oil getting into the combustion chamber, by the oil rings or the valve stem seals.
Smoke from the valve covers is a sign of blow by, or oil temperature problems. Blow by will actually blow the oil ring out against the cylinder walls, and stop oil from getting by. With good quality modern rings, odds are your problem is the hone, or what you're doing to assemble the engine.
Call Keith or Kevin at Total Seal.
The proper way to test cylinder seal is with a blow by meter on the dyno, with a Dwyer guage, there's no real substitute There's a video on youtube, by Lake Speed Jr.
Alan -- what are you thoughts or results on using sleeves in BB blocks ??
Bob Sherwood is offline   Reply With Quote
