What brand of lifter is everyone using in there 350 superstock motors. I have 45 used comp lifters, should I send them back to get rebuilt?
Liked 1,923 Times in 432 Posts
Comp has a very good rebuilding program, I use it for several customers.
Comp also has a new Sportsman series, which falls between the Endur-X series and the Elite series, and is available with roller bearings or a solid bushing style bearing. One of the best things you can do is upgrade to the 0.904" diameter lifters, if you're still running 0.842" diameter lifters.
Alan Roehrich 212A G/S |
Liked 1,984 Times in 597 Posts
Morel with high pressure pin oil. Very nice lifter you can get them from Bullet I have run the rebuilt comps with good luck too.
Mike Pearson 2485 SS |
Liked 20 Times in 15 Posts
The Crower bushed lifters are very nice, not cheap though. Then again when those needle bearings fail that extra money will be very well spent.
See if those Comp's can be rebuilt with the bushings. |
As far as I know, Comp will not change a lifter with roller bearings to the sleeve bearing. And the only lifter they have listed with the sleeve bearing as an option is the Sportsman series.
Thanks guys
