Old 01-19-2009, 06:23 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Fuel line??
What material (braided line?) is recommened to use from the
fuel pump (in trunk) to the fuel regulator on the inside front fender?
The rest of the system is #8 line and fittings.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-19-2009, 08:03 PM   #2
FED 387
Liked 335 Times in 182 Posts
Exclamation Re: Fuel line??
Why not run a -12 then you will have as large a line as you may ever have a need for---can't hurt better to big than too small right??? Too big definately will not hurt it while too small and you will always have problems---Comp 387
Old 01-19-2009, 08:27 PM   #3
72Malibu
72Malibu's Avatar
Default Re: Fuel line??
What about G forces trying to make the fuel flow backwards if the line is too big? I started using braided line, but switched to the pushlok stuff, I think its easier to use. I use -8 an to feed 650hp or so.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 01-19-2009, 08:36 PM   #4
FED 387
put 2 pumps on it with a bypass to return any unnecessary fuel to the tank!!!!!!!!!!!!!!!!!!!!! I hardly believe that G forces of any significant amount come in to play here on a Stocker or S stocker----Comp 387
Old 01-19-2009, 08:40 PM   #5
Keith 944
Keith 944's Avatar
not as pretty, but aluminum line is a lot cheaper. run to punp, then nice braided.
Old 01-19-2009, 10:06 PM   #6
FED 387
look on Ebay and get some left over or used from a Nascar team probably for 25% of new-Its your car do it however you want I know what I'd do and it would not be aluminum line!!!! comp 387
Old 01-19-2009, 10:57 PM   #7
Steve OB
Steve OB's Avatar
Send a message via Yahoo to Steve OB
Aeroquip Socketless hose.
A lot cheaper than braided, approved, reusable ends, & easy to work with.
I use it on my entire fuel system & radiator hoses on my bracket car.
Good Luck!!
Steve Obertanec
Steve OB is offline   Reply With Quote
