Old 10-17-2011, 04:18 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Default synthetic racing oil?
i have been running rp racing 21 oil for a couple of years. was wondering if there was a similar oil that you could buy for under $10/quart. was looking at the valvoline full synthetic 10w/30 oil racing oil. i checked the price at o'reilly's $9/quart. i love the royal purple but just trying to find something a little less expensive. any help would be greatly appreciated. thanks jason i run a 327/275 ss combo
jaf2021 is offline   Reply With Quote
Old 10-17-2011, 05:26 PM   #2
Reed Granrt
Default Re: synthetic racing oil?
If you have a known good product, why would you worry about saving $5 or $6 dollars on a oil change. I play most every day to get 5 more hp and want the motor to last, so I look at oil much differently than you do. I want the best I can get and THEN I worry about money. The smaller the motor, the more I look too oil to get that extra power. 5 hp on a 283 is much better than 5 hp on a 427, but 5 hp is 5 hp.
reed
Reed Granrt is offline   Reply With Quote
Old 10-18-2011, 07:34 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: synthetic racing oil?
I've been very happy with Amsoil products. They've come out with a line called "Dominator" which includes 5w-20, 10w-30 and 15w-40, all with extra zinc & phosphorous for flat tappet cams. I use the 5w-20 which I'm pretty sure can be gotten for less than $10.
While I never had the luxury of putting an engine on a dyno, the most obvious and simple example I've seen of how well it works is when I change from conventional straight weight 30w or 40w oil used for break-in. I have to adjust the idle down every time - no other changes. It has helped ET over other conventional oils, but it's been a while since I switched. I've never bothered to compare it to other synthetics on the track, but I sincerely doubt there would be much difference.
http://www.amsoil.com/techservicesbu...t%20tappet.pdf
If you need source and contact info, feel free to PM me.
Old 10-18-2011, 07:48 PM   #4
gtnorman
congrats on your award myron, amsoil is good stuff.
gtnorman is offline   Reply With Quote
Old 10-19-2011, 03:46 PM   #5
Scotty D
try looking into cam 2 blue blood racing oil it comes in different formulations and is very reasonably priced.summit is now handling it to make it easier to get.
Scotty D is offline   Reply With Quote
