Old 03-02-2012, 04:35 PM   #11
Hemi Moose
Liked 12 Times in 12 Posts
Default Re: Old Race Parts and Pieces
Originally Posted by James L Miller View Post
He bought it at a swap meet in Florida. The casting date is 10-17-63. There are two articles that have been published on that block. One is in the Mopar Collectors Guide, the other was in Mopar Muscle magazine. We have a mutual friend, Stewart in Tampa, that used to hang out with the Mopar Missile crew back in the early 1970s. I was fortunate enough to be included in the early rounds of figuring out this block. The AAQA stood out for me. Bill Weertman thinks it was used for valvetrain testing as one of the head stud bosses cracked, making it useless for engine testing. Apparently the EXO marking also lends to the theory that it wasn't a running engine. I don't know if Hoover has seen the block, but the Missile gang usually makes it down for the Gators, so I'm sure Olfield has seen it and probably Joe Pappas. I got to meet those guys at the 2008 Hemi Reunion in Ohio thanks to Stewart.
You should tell some of those old racers to come join in the fun and shoot the bs on here...l'd love to here some more old stories on these warhorses by them.
Old 03-02-2012, 08:49 PM   #12
Frank Castros
Liked 2,793 Times in 983 Posts
I once had a 426 Wedge block with the AAQA designation and Jerry Stein told me it was a great block because of it's high nickel content. He was right about it being a great block as we went our best numbers with it.
Old 03-05-2012, 12:00 PM   #13
James L Miller
Liked 25 Times in 16 Posts
Well, I don't want to turn this thread into Mopar only. I thought it would be neat to see lots of odd/rare parts from the Big 3 and maybe the not-quite-as-big #4 (AMC). I found some pictures of a Pontiac RA V head. It looks a lot like the Ford Tunnel Port on the intake side. They must have changed the cam lobes on some cylinders since the valve spacing/arrangement is different.
Name:	RA V Chambers.jpg
ID:	10956   Click image for larger version
Name:	RA V Exhaust.jpg
ID:	10957   Click image for larger version
Name:	RA V Intake.jpg
Mopar 2 Ya!
Old 03-05-2012, 12:20 PM   #14
James L Miller
OK, this is an oddball engine and definitely not a race engine. Ford made some all aluminum V8 engines during WWII (The BIG ONE). The GA series engines started out as a V-12 (thus the 60 degree Vee) aircraft engine (explains the all-aluminum part), but the government already had enough aircraft engines (Allison and Packard built Merlins), but they needed a tank engine. They lobbed four cylinders off to make an all-aluminum V8 of 1100 CID. They had two puny carbs on it. I think it could use three Holleys for a bit more power.
ID:	10959   Click image for larger version
Name:	GAA Late_Model_Block_Bottom_View (428 x 480).jpg
ID:	10960   Click image for larger version
Name:	GAA_Engine_Layout (518 x 480).jpg
Mopar 2 Ya!
Old 03-05-2012, 03:25 PM   #15
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
http://www.ebay.com/itm/1955-1964-PO...sories&vxp=mtr
Old 03-05-2012, 03:35 PM   #16
Hemi Moose
The big 3 made a lot of experimental parts & pieces back in the late 50's through the early 70's...anyone else here remember any other weird stuff.
Old 03-05-2012, 03:45 PM   #17
Hemi Moose
And there were several aftermarket companies such as Mickey Thompson...
M/T Pontiac Super Duty Cross-Ram intake manifold...
Old 03-09-2012, 05:28 PM   #18
Hemi Moose
Great topic
This should bring out some neat stuff.
How about the "questionable" legal parts that are no longer relevant?
Show us some of the trick stuff from back in the day.
Do you have anything off the top of your head regarding legal parts...I guess this could apply to a few stock & super stock classes including pro-stock back then.
Old 03-09-2012, 06:29 PM   #19
Nothing specific.
Maybe something that was run for a while and then got busted at tech.
Parts that pushed the limits of legal but only if the process/method is not something that is being done now.
Don't want to get any current rides busted!!!
And...like is being shown above, just some cool old stuff.
Old 03-09-2012, 06:30 PM   #20
Hemi Moose
It was rumored that Jimmy Addison's '67 GTX called the 'Silver Bullet' was a test bed for Chrysler performance parts back in the day...
http://www.dragzine.com/features/car...silver-bullet/
