#51 | |
Liked 373 Times in 129 Posts
#52 |
Liked 99 Times in 49 Posts
What engine trans do you plan on using,also convertors play a big part of how a stocker leaves the line.Be aware that Alf rear kit was deamed illegal a while back, it may have changed now. When one Alfs kit was installed on a69 chevelle stocker it did not pick up anything. It did make the car leave better no twist body roll ,but no quicker.If you plan to run a 396-375 or 427-425 then buy Alfs kit.
#53 | |
Liked 53 Times in 16 Posts
I was just catching up on some of these post. What do you mean by- "You really want a ball type pivot on the bottom with a strut rod type suspension." Are you talking about a Heim type joint at the end of the strut rod where it goes through the frame up front? I will probaly use a rubber bottom bushing with the serrates removed, do you think this would be a better option so I can address the caster issue? Thanks for any input- Will Lamprecht Div 1 65 imp I/SA |
#54 | |
Liked 30 Times in 17 Posts
#55 | |
Liked 759 Times in 379 Posts
Again, I've got no time to debate the same old sh_t with the same guy about a car that I sold 5 years ago, I've moved on long ago but for those that want to know the FACTS and the TRUTH, there's several threads here including this one... http://classracer.com/classforum/showthread.php?t=40441 just do a post search on that guy. Last edited by 1320racer; 10-16-2013 at 09:26 AM. |
#56 | |
Liked 535 Times in 110 Posts
Jim Kaekel 3836 STK |
#57 | |
Jeff Lee 7494 D/S '70 AMX |
#58 |
I thought this thread was about "Front End Suspension"
and neither do the biggest and winningest names in stock and super stock! ![]() For those like you that think they are special, claiming to build their own engines because you/they clean your parts, apply some assembly lube, check/set a few clearances, gap rings and torque a few bolts, this is for you... over at least the next 5 months, Tilburg's, Gulius's, Watters's, Patterson's, Bischoff's and other's engine shops phones will be ringing off the wall and their shops full of the engines for and from the biggest and winingest names in class racing just as will Sunset's, Reher Morrison's, Par's, Shafiroff's, Schimdt's and others with their shops full of and building engines for the who's who of super comp, gas, street and bracket racing. That said, YOU too buy your engine parts just like I do and the vast majority of class and bracket racers do. YOU too pay a machine shop to do your machine work just like I do and the vast majority of class and bracket racers do. YOU too pay to have your engine dyno'd just like I do and the vast majority of class and bracket racers do. So if it makes you feel smarter, makes you feel superior than the majority of us that don't, WE are ok with that and don't worry, we won't tell anyone the truth!. ![]() Further, last I checked when reading National Dragster, the NHRA doesn't award Wins, Wally's or $$ for those who's claim to fame is they built their engine! Fletcher along with the biggest names in NHRA Sportsman racing don't build their own engines but somehow, he just managed to win his 84th and 85th Wally. ![]() Oh and btw, the vast majority of class and serious bracket racers don't build their cars, carbs, transmissions, converters and headers and neither do you! ![]() Last edited by 1320racer; 10-16-2013 at 11:37 AM. |
#59 |
1320 Racer: For your info, I do assemble my own engines and build my own transmissions. No, I don't think I'm better than anybody else because of it, but it's what I can do and afford. I literally grew up working in my dad's automatic transmission shop from '75 until '95 and I've worked at a high performance parts distributor since, so I feel I do have knowledge that I'm willing to share with others. I'm 54 now and smart enough to know that you've just got an oversized ego problem.
#60 | |
Liked 5,138 Times in 1,961 Posts
The heim on the end of the strut....I'm not sure where we left off on that controversy.
