#61 |
Liked 557 Times in 217 Posts
It was/is pretty common to weld some straps on those perches....but I never saw a failure like that even without them.
You have a ton of work to fix that....pull rear cut off perches....weld on new ones...add strapping....check everything else for damage... If it is legal a strap going over the top of the axle and down to the perch front and back should work. The metal that those perches are made from is questionable in my mind... That's a nice car....I would love to have it....and will be fun to race when you get it fixed....
#62 |
Liked 33 Times in 16 Posts
You are right...a ton of work required for no good reason. Pretty bummed about Moser atm...why use such cheap parts? I'm going to order those Calvert perches and have a local builder do the job. I may be wrong, but my gut feeling tells me Moser would be a long stall in getting any satisfaction and we want to race sometime this season.
Rich Taylor I/SA - 321 |
#63 |
Liked 485 Times in 160 Posts
I would call Moser and give them an opportunity to correct the situation.They should be on the hook for this and fix it asap,saving you some $. If you don't get a warm fuzzy feeling on the phone then you may want to go elsewhere. With social media such as this forum I would hope they view this problem as an opportunity to provide a solution and turn it into a positive for all of us to read about !
The company I work for monitors the web constantly for any such issues and jumps all over them to minimize any damage to it's reputation. |
#64 | |
#65 |
Liked 110 Times in 29 Posts
Rich:
Did you extend the axle housing locator pin through those aluminum spacers and shim? |
#66 |
I agree with Tim H. Moser has a good rep for supporting their customers.
You get better results with honey rather than vinegar... They probably buy those perches from a vendor and on a street car they would be fine. On a racecar with a 3 speed with a steep first gear they are not strong enough. Should they know this...well yes they should. Call them.
#67 |
This is a must do...pin will pop out and rear will move. Been there done that 40+ years ago....
#68 |
Liked 1,865 Times in 435 Posts
Check out Calvets pinion angle shims .
james perrone 1290 STK |
#69 | |
For the prior post - The Calvert blocks have their own locating dowels which mesh with succeeding stacks. This was not an issue here as nothing slipped...the flimbsy perches merely collapsed. When I call Moser I will ask if they will repair the housing and replace the perches with Calvert's which I will provide since they obviously don't have a suitable replacement. I'm off to the shop shortly to strip the housing out of the car.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-02-2014 at 10:16 AM. |
#70 |
Liked 44 Times in 19 Posts
Didn't Paul Wong have something like this happen to his truck at Stanton last year?
Marty Knox 3071 STK |
