#11 |
Liked 11 Times in 8 Posts
Ok, Bobby how bout this. Where is your MAP located..in the ECU or out, in either case why don't you try this. Disconnect the vacuum hose from the engine that hooks to your MAP sensor install a hand operated vacuum pump and pull a vacuum on sensor to around 40ish PKA see how your Pulse width responds, it should go down. Looks like the MAP is very high in the idle shot you posted, other than that and the fact your P.W. looks extremely high the rest looks normal to me. Another check is to use your vacuum pump and pull a vacuum...read the gage (on the pump) and see if it is close to what your ECU is reading. this should tell you if the MAP is skewed or not. Please try this if you can and let us know the results. Not knowing your set up (engine size, injectors cam, ect.) I'm merely guessing but I'd expect to see maybe 2.9-3.? M.S. of pulse width at idle. Again good luck. Joe, Bobby I also noticed you have nearly 2 volts difference in batt. voltage. Though I don't believe that is causing the issue you have you need to be aware that voltage has a direct effect on the injector "on time" just something to think about. On another note does your ECU have any type of "blending function" to blend between the TPS and the MAP sensor to correct for poor MAP signal @ idle?
Joe Buchanan SS/BX 3117 Last edited by buzzinhalfdozen; 04-04-2014 at 01:01 PM. |
#12 |
Bobby, if you can please try the test I described using a hand held vacuum pump as I'm quite certain the MAP input you're seeing at idle is the cause of your rich fuel mixture. Please try and see if the gage and your MAP reading on the laptop agree while applying vacuum to it...you can do that with the engine off. If they are off by a wide margin then there you go, if not then please post up the results of bringing the MAP to around 40ish with the engine running and see if your pulse width number decreases. Joe
Joe Buchanan SS/BX 3117 |
#13 |
I can't read his gauges on my phone.
My raggedy-azzed junk idles about 65 KPA.
Ed Wright 4156 SS/JA |
#14 |
Liked 240 Times in 112 Posts
It show's -1.9 psi @ idle & -6 @ 2500. Your 65 KPa @ idle converts to -9.5 psi. On the scanner I used to use it would show an actual O2 reading & a light would come on showing when it went into closed loop. Does this software do that ?
Dave Noll, EF/S ,?/SA 6526 |
#15 |
Ed, his is 86.xx KPA @ idle. Reason for my reply, not far off Baro, tells ECU engine is under heavy load (well you know that) reason for extra fuel.
#16 |
Liked 269 Times in 99 Posts
If open loop the O2 Sensor is out of the equation but stills is reading way lean if the plugs are showing very rich.
If the MAP sensor is the problem why not just unplug it. The ECU should go to a predetermined value and should adjust the fueling with TPS and Temp Sensors. Probably very similar to Alpha N. Go into the fueling map while running and lean out the cells being used paying attention to the idle rpm and how the car sounds. Lower the fuel pressure will lean out the whole map. Just throwing out ideas. If the sensors you are using are all used unknowns get everything new, Rock Auto is about as cheap as you may find unless your local parts supplier gives you a good discount. If you are not confident in working with the fuel map call your tuner or bring the car back to him. May be money well spent.
#17 | |
Liked 4 Times in 3 Posts
our DFI's are much older but if the harness plugs match up we should be able to test it for you on our cars. if all is well the readings should be the sameon our laptop
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
#18 |
86 KPA is way wrong.
#19 |
Liked 4,389 Times in 505 Posts
Guys thank you very much for all the replies and advice. I'm at work and just got a free min to check my phone. All I checked on map sensor today was I watched the voltage drop when pumping but didn't do an exact measurement of hand pump HG to laptop kpa display cause I had to leave. Alex and Tony I will snap pics of those plugs when I get home. Also David Barton thank you for your generous offer.
#20 | |
