Old 12-07-2016, 08:44 AM   #31
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Re: Lifter rule in Stock
It would have been so easy to add the above statement to the rule change!
As written, it creates all kinds of conclusions and assumptions by engine builders and racers
I agree with the above. ^^
If that was NHRA's intent then the revision should have come out and stated that hyd. flat tappet lifters can be replaced with solids.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-07-2016, 09:34 AM   #32
Rick Schilling
Liked 14 Times in 10 Posts
I know this should be obvious, but if your combination already uses hydraulic roller lifters you can convert to solid rollers now?
Rick Schilling is offline   Reply With Quote
Old 12-07-2016, 09:57 AM   #33
Billy Nees
It seems to me that going from a heavy hydraulic roller to a (fairly) light race-type solid roller should do wonders for the RPM potential of a bunch of modern Stockers!
Billy Nees 1188 STK, SS
Old 12-07-2016, 11:57 AM   #34
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Lifter rule in Stock
Seems to me that after a lot of good intelligent questions have surfaced and been discussed, a rule clarification will probably be forthcoming. Yes, Billy, the solid roller lifter comment is a real good probability that RPM's might possibly be affected for good. I know that a mechanical lifter camshaft has clearance ramps included on each end of the lobe configuration to allow for lash, and that the overall lift also compensates for valve train lash. If you tried a set of mechanical lifters on your existent hydraulic cam, what would you use for lash on an initial effort before replacing the cam?We're talking going to a test and tune,not some kind of national event.
Old 12-07-2016, 11:57 AM   #35
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Holy Super Stock Batman !!!
Stockers with SOLIDS !
D
Old 12-07-2016, 12:00 PM   #36
ALMACK
ALMACK's Avatar
D
One step closer to SS for sure Dan
I/PS '95 Mustang GT
Old 12-07-2016, 12:34 PM   #37
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
A cottage industry of high tech, high dollar stocker hydraulic lifters is made obsolete overnight by the stroke of a pen...
Bob Don 128 SS
Old 12-07-2016, 01:08 PM   #38
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
If they are going to clarify the rules...what about the diameter?
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 12-07-2016, 02:16 PM   #39
jimi
Liked 21 Times in 8 Posts
been using solid lifters on hydraulic cam grinds for years in street cars adjust the lash at.006".
Old 12-07-2016, 07:26 PM   #40
Greg Reimer 7376
I assume that would have to be at or near operating temperature. Also, how much would you gain over these "Limited Travel" lifters?
