Old 04-09-2017, 07:47 AM   #81
monte385
Liked 27 Times in 19 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Couple of pics , I should have taken some before I put them on.
http://myweb.midco.net/77cruiser/100_0554.jpg
monte385 is offline   Reply With Quote
Old 04-14-2017, 05:06 PM   #82
Jeff Stout
Liked 706 Times in 283 Posts
Here is the bolt added for strength so the weld would not be a butt weld.
Also this week I was able to get fuel cell mounted. It wasnt legal for dirt track car so I used it here and mounted pump and lines. All this stuff was on shelf from other race car.
Old 04-17-2017, 03:54 PM   #83
Jeff Stout
My 307/138 engine with 87k for miles
Old 05-01-2017, 09:02 PM   #84
Jeff Stout
Bought a brand new set of thinner wall .980 wrist pins $67.00. New inline fuel filter $24.00. Heads are being surfaced and were .009 warped. When taking motor apart this head had 1 head bolt broke. The actual hex head of bolt was broke off and sitting in bottom of head by oil return passage. Found the right thickness head gasket with small bore and bought 2 sets $56.00. New total $3484
Old 05-02-2017, 07:26 AM   #85
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Jeff, I really appreciate the effort you are doing to document your costs as you go. At the end of the project, it will be a great resource for anyone considering a budget build. Thank you for sharing and working so diligently.
Old 05-02-2017, 09:46 AM   #86
Jeff Stout
Thank you for the kind words. I know this is not the state of the art build and it is not the best pieces money can buy. But I feel I can run 7-8 under and be bracket race competitive. Just think no roll bar to climb over, full soft bench seat, room for all your friends and might get as much attention in staging lanes as a FX car. LOL
Old 05-02-2017, 11:14 AM   #87
Dwight Southerland
I have built budget cars that took a lot of thinking and expensive cars that took a lot of money. The ones that were the most fun were those I did like yours.
Old 05-02-2017, 07:02 PM   #88
Jeff Stout
Made a mistake today on guessing how much to cut from head to get chamber down to proper CC. Way to far to get back to spec. Had to buy a used head for 60.00 and received cam bearings today 11.50 New total $3555.50
Old 05-02-2017, 08:20 PM   #89
SSDiv6
Jeff,
I usually takes about 0.005" ~ 0.006" of deck surface removal per CC of combustion-chamber volume for an Oldsmobile cylinder head.
However, this is a guideline and you need to constantly check it.
Old 05-02-2017, 09:23 PM   #90
Dwight Southerland
Jeff -
If you have a burette available, PM me and I will show you an easy way to get real close on the CC volume on one cut.
