Old 08-15-2021, 04:39 PM   #21
Dragsinger
Liked 99 Times in 60 Posts
Default Re: "Family Tradition" a build for Daughter & Grandchildren
ladder bars
ID:	58271   Click image for larger version
Larry Woodfin 471W
Old 08-16-2021, 04:19 PM   #22
Dragsinger
Competition Engineering Anti-roll bar
Larry Woodfin 471W
Old 08-23-2021, 06:18 PM   #23
Dragsinger
It is not necessary to have caster wheels, but it helps.
ID:	58400   Click image for larger version
Larry Woodfin 471W
Old 08-30-2021, 11:25 AM   #24
Dragsinger
Strings are an important tool
ID:	58644   Click image for larger version
Larry Woodfin 471W
Old 09-04-2021, 10:49 AM   #25
Dragsinger
An interesting update. I have decided to scrap the plans for a conventional SB engine. Instead, to move my engine knowledge into the current century, I will be building an LS-series engine. Would you please check back often as we learn how to do a carburated LS drag engine?
More soon as I decide on which block and what size engine.
Larry Woodfin 471W
Old 09-04-2021, 08:48 PM   #26
SSDiv6
You have a few options for ignition. Actual front cover with distributor, offered by GM and other companies; or MSD or Daytona Sensors standalone ignition box.
My preference is the Daytona Sensors Smart-Spark standalone ignition box. Allows for a clean and simple installation, offers many options for RPM control and after you map your ignition, it has small knobs to do adjustments at the track without the need of a laptop. Also, they have great customer support.
http://www.daytona-sensors.com/smart...ol-module.html
Old 09-04-2021, 10:03 PM   #27
Dragsinger
SS, Thanks for the info.
Larry Woodfin 471W
Old 09-05-2021, 02:08 PM   #28
Bill Moulding
Couple of things I learned on my ls build. If you are using a stock crankshaft be sure to check the thickness of the flange on the back. Some early 4.8 and 6.0 cranks have a thicker flange (1.250) where the majority have a .857. The thicker flange uses a flat flexplate and the others use a dish style. A crank from a FWD car is different again. I used a Hughes 4004X flexplate it has multiple convertor attatchment points.
I used an ATI 917215 balancer which has timing marks and needed to be pinned to the crank. A few companies make a fixture for this but instead because my engine was disassembled I had the machine shop cut another keyway in the snout. Then used ATI 916631 drive mandrel for the vacuum pump and alternator.
Worked for me.
Bill Moulding is offline   Reply With Quote
Old 09-05-2021, 05:39 PM   #29
nickh
nickh's Avatar
Liked 667 Times in 201 Posts
Larry here is a 5.3 LS motor not to far from you. $650 not bad for complete motor, easy to get 600 hp out of these with stock bottom end.
https://www.facebook.com/marketplace...Anull%7D%22%7D
