Old 07-16-2022, 05:24 AM   #611
Liked 10,927 Times in 2,258 Posts
Default Re: Dumbo The Flying Elephant
I’ve forgotten who told me this years ago, It’s just a math problem and try to get the numbers to like each other.
Old 07-16-2022, 02:11 PM   #612
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
Sounds like Kenny Duttweiler- the entire world is just a math problem to be solved....
Old 07-18-2022, 10:10 AM   #613
Frank I am not gifted! I try real hard to follow directions that smart people were kind enough to share with me.
Again thanks to all that have help me over the years.
Old 07-18-2022, 08:03 PM   #614
At the PRI show I purchased every height micrometer that PAC sells. I thought I had all the bases covered, not so. The new Hemi is a little different from anything out there. To make a long story short I had to find an adapter in a piece of bar stock. It works well. Supper time got to go.
Old 07-20-2022, 02:07 PM   #615
Setting up to make custom shims for Dumbo, sometimes times I feel like the Dumbo.
Old 07-22-2022, 06:58 AM   #616
Today I should be able to assign springs to valves get them assembled and verify coil bind. It should be a busy day.
The reason for all the lathe work is the valve guide bosses have a healthy radius at the bottom where the spring cup or shim seat. Some of the shims I had to turn the OD down to fit the pockets or bore the ID to go over the guide boss.
ID:	64051   Click image for larger version
Old 07-24-2022, 02:30 PM   #617
Greg West
Liked 52 Times in 22 Posts
Amazing all the work involved to build a fast race engine. Every detail needs to be checked and double checked. Awesome work Larry.
Greg West is offline   Reply With Quote
Old 07-26-2022, 08:43 PM   #618
The worst thing about building you own race engine is I have no one to blame but myself. I wake up in the middle of the night and think of things I need to do or forgot to do the day before. It makes for a less than restful night.
Old 07-27-2022, 12:57 AM   #619
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Ibuprofen-PM especially after crawling in and out or under the car.
Mike 7570 A/SA
Old 07-28-2022, 06:38 PM   #620
After redoing my coil bind set up three times I'm confident that my numbers are correct and repeatable. I have one head ready to bolt on for final check for clearance from coil bind. The other head is clean with seals, valves, and ready for spring assignment with assembly. It took two sets of springs to get eight springs on the intakes to all be at the same open and seat pressure. The exhaust side springs are 10 pounds lighter on open and seat.
Does anyone have the old style Larson Systems Solid Height Gage, if so I think I would be willing to purchase it.
More later
