Old 04-24-2023, 04:53 PM   #31
jmcarter
jmcarter's Avatar
Liked 3,247 Times in 987 Posts
Default Re: S/ST-S/G Alfa Romeo Spider Roadster
Kool! Your tubs can double as contingency stickers!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-24-2023, 08:07 PM   #32
Jerry Terry
Jerry Terry's Avatar
Liked 452 Times in 134 Posts
Absolutely awesome Keith cant wait to see it out !!
Jerry
Retired 3490 3492 STK SS SST
Old 04-25-2023, 07:51 AM   #33
Keith 944
Keith 944's Avatar
Moving on to some wiring, and stereo installation, you know, the important stuff
ID:	67006   Click image for larger version
ID:	67007   Click image for larger version
ID:	67009   Click image for larger version
ID:	67010   Click image for larger version
ID:	67012   Click image for larger version
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-25-2023, 08:00 AM   #34
Keith 944
Keith 944's Avatar
Got some parts powder coated, put in the jones racing trans system, this pumps fluid while the car is off allowing quick cool down.
Added the fuel system. I believe at this point I had the car running and moving around under its own power
ID:	67014   Click image for larger version
ID:	67015   Click image for larger version
ID:	67017   Click image for larger version
ID:	67018   Click image for larger version
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-26-2023, 07:59 AM   #35
Keith 944
Keith 944's Avatar
It was time to paint the cage to finish up the interior now I can cover it and focus on the outside again, I used green, gold, and silver pearls in marbleizer to get this effect. This will also be used in the stripe later
ID:	67021   Click image for larger version
ID:	67022   Click image for larger version
ID:	67024   Click image for larger version
ID:	67025   Click image for larger version
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-27-2023, 08:15 AM   #36
Keith 944
Keith 944's Avatar
Time to start on the outside body work, I made new rocker panels to fit the extensions and to level the cars stance to 4-1/2 off floor
ID:	67031   Click image for larger version
ID:	67032   Click image for larger version
ID:	67034   Click image for larger version
ID:	67035   Click image for larger version
ID:	67037   Click image for larger version
ID:	67038   Click image for larger version
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-27-2023, 08:21 AM   #37
Keith 944
Keith 944's Avatar
Now I have to fill that 7” gap I made in the hood area and to cut down and mount the scoop
ID:	67040   Click image for larger version
ID:	67041   Click image for larger version
ID:	67043   Click image for larger version
ID:	67044   Click image for larger version
ID:	67046   Click image for larger version
ID:	67047   Click image for larger version
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-27-2023, 08:25 AM   #38
Keith 944
Keith 944's Avatar
I need to add that I made the front end removable, it can tilt or slide off, the hood opens from the rear. That was nice because I could get a nice tight fit from the scoop to the windshield. The cowl panel is now in 2 pieces and is removable for engine servicing
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-27-2023, 08:39 PM   #39
nickh
nickh's Avatar
Liked 692 Times in 205 Posts
Keith Love the build, you may have found a second calling..LOL
How tight will it be to reach the 3 back plugs?
Old 04-27-2023, 08:52 PM   #40
Keith 944
Keith 944's Avatar
Thanks bud, and it's really not bad, especially if you take the three fasteners out of the cowl and remove, all open to the windshield. hard part is if you need to take the distributor out, engine has to go. but still not bad
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
