Old 10-10-2023, 07:08 PM   #11
Kirk Morgan
Liked 81 Times in 45 Posts
Default Re: 1979 C-10 Shop/Race Truck Build
Are you doing dyno work in Texas? Little River has a lot of history.
Kirk Morgan is offline   Reply With Quote
Old 10-11-2023, 08:42 AM   #12
Woodfin
Liked 288 Times in 109 Posts
Just a brainstorm about the truck project. You could fine a short bed and convert the truck to a shorter wheelbase with a one-piece driveshaft.
Old 10-11-2023, 10:24 AM   #13
HP HUNTER
Liked 373 Times in 129 Posts
We almost bought Larry Hills stocker truck, and then I would have had a mid 10 sec truck, it was my wife's idea, but I was worried about getting it emmisioned for street use, because we drive this truck a lot. And actually I like my own truck. We were going to get it shortened and the shop that was going to do the work was getting flaky, and was worried about the chassis being square, but that's definitely
a option if I can find someone I trust.
Old 10-11-2023, 10:27 AM   #14
HP HUNTER
Yes-we dyno test.
Old 10-11-2023, 10:37 AM   #15
HP HUNTER
So I started my 350 build, .060 over 2 bolt 010 block, I did some work to the factory cast crank which ended up @ 3.483 stroke, I put a 6 inch rod in there with a + 6 cc dome Mahle piston, my Fuelie heads came in at 74 CCs which gave 10.8 compression. My solid lifter cam was .528 lift @ the valve with 264 @ .050 duration on both sides, 108 lobe separation. I used a Performer RPM intake with a 750 Holley, the Moroso pan was modified.
Old 10-11-2023, 07:37 PM   #16
HP HUNTER
A picture of my new 350
Old 10-11-2023, 11:10 PM   #17
HP HUNTER
The 350 with 4 passes delivered the following performance in street trim with the power steering and steel two piece drive shaft @ 3970.
1.50 60 foot
7.04 660 @ 94.2 MPH
https://youtube.com/shorts/aS_Mx_tTz...4QheGAyGXu5mMu
More to come.............
Old 10-14-2023, 06:19 PM   #18
Woodfin
Which track is the video?
Old 10-15-2023, 09:30 AM   #19
Liked 10,850 Times in 2,254 Posts
You truck looked and sounded very good on the track. Congratulations
Old 10-16-2023, 09:33 AM   #20
HP HUNTER
Thanks, I should have bought your truck, as I've destroyed the factory leaf springs, pinion angle will not stay in place.
