Old 10-18-2023, 12:20 PM   #21
Ellis V Buth
Liked 420 Times in 73 Posts
Default Re: National Record Postings
The minimum that is posted is already .5 under the index. You would only have to exceed that to set a record.
Mark is right. It is .5 under the index to set a record. W/SA, for example, has an index of 16.65. The minimum is 16.15. So if I wanted to set a record, I'd need to make 1 run of 16.149 or quicker and then another run within the range to count as a backup in order to reset the record from minimum.
Ellis V Buth is offline   Reply With Quote
Old 10-18-2023, 01:24 PM   #22
Charles Stewart
Liked 755 Times in 213 Posts
I'm questionning myself regarding the word "minimum" here.
The way I see it, if you make a run at 16,15 with a back up run in the range, you will have the record, It's the minimum required.
Charles Stewart is offline   Reply With Quote
Old 10-18-2023, 04:48 PM   #23
Charles Stewart
Originally Posted by fred goodwin View Post
So Charlie are you saying one would have to go .5 under the minimum.or .5 under the index to set the record?
Hum, my answer wasn't clear at all. It's .5 under the index to set a new record when the word "minimum" is indicated.
Thanks Mr. Goodwin.
Old 10-18-2023, 05:15 PM   #24
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Thanks fellas! I got it now, I was just a little confused on the wording!
fred goodwin is offline   Reply With Quote
Old 10-19-2023, 08:18 AM   #25
Adger Smith
Liked 880 Times in 311 Posts
Charlie,
To me it looks like if a record is to be put in the books it is going to have to be .5 quicker than the index.
I never have seen the word Maximum so I would assume (yep I know what that does) a 1.30 or quicker run gets you in the books, but costs you..
Back to assuming... AHFS probably has a little something to do with the lack of record setting.
Adger Smith (Former SS)
Old 10-19-2023, 05:41 PM   #26
Marty Buth
Liked 232 Times in 39 Posts
Originally Posted by Adger Smith View Post
Charlie,
Adger, National open runs don't count for the AHFS, so if you want to go 1.30 under or quicker you go to a National Open.
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 10-19-2023, 10:05 PM   #27
killintime6968
Liked 91 Times in 29 Posts
If you had a bunch of gaskets and don't mind a lot of work you could paper a wall with records. Go .55 under wait a couple weeks then go.60under then a couple more and go .65 and so on. LOL It sure would be good practice .
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 10-22-2023, 05:34 PM   #28
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Originally Posted by Jim Kaekel View Post
https://www.nhra.com/stats/national_records
Glen: I see yours listed from 2022 on this National Record listing.
Wow !
Look at all those " Minimum" listings
Originally Posted by kansas stocker View Post
Remember the old days when you ran under the record, backed it up, were tore down and then wrote your accomplishment on the side of the car? Your feat was then validated in every issue of ND. Made you a BMF. Sweet memories of days of old. Pete
Too bad NHRA will not dedicate at least 1 page every 3 to 6 months in National Dragster to list all the current record holders.
Instead, they believe we want to see a giant " grainy and somewhat blury" black and white photo from 1958 ( or thereabouts )
What a waste of page space...
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-22-2023, 07:00 PM   #29
bubski
Liked 165 Times in 60 Posts
Bracket 2 has invaded Stock n SS just like our borders are invaded !! There's no goin back to the "performanced " based Class !! That is on its last breathe's as everyone got their chest pumped out doin whatever they want !! With their bracket 2 S/SS "cars" No need to go n break or set records when the MASSES don't even know what they are or what it takes to be the standard of the class !! NHRA realizes this n won't print anything about it because it's a moot point in bracket 2 !! WTF !!
bubski is offline   Reply With Quote
Old 10-23-2023, 08:06 PM   #30
dean ribeiro
Liked 241 Times in 80 Posts
Originally Posted by JIM MARSHALL View Post
It took me 6 months to get my record certificate from the last record I set in Rockingham only to say J/A instead of J/SA . NHRA could care less about record holders. I was the first one on the tear down list at Indy last year when the place was full of racers that have never been looked at. I took the same car apart the previous year and makes no difference to them. I know I’m done wasting my time and money setting records. I have a great time racing with the CCRA and the NMCA.
Sorry Jim, but that hotrod belongs running in J/A
dean ribeiro is online now   Reply With Quote
