Old 05-30-2024, 05:59 PM   #91
Billy Nees
Liked 7,854 Times in 1,750 Posts
Default Re: U/SA 302 ffffford build
You can use a radiused cutter. That's not illegal.
Billy Nees 1188 STK, SS
Old 05-30-2024, 06:04 PM   #92
Liked 5,145 Times in 1,964 Posts
Originally Posted by Glenn Briglio View Post
What angle are you referring to ?
Glenn, I am referring to the angle that is built into the valve.
Always fun to go into a teardown with a Pontiac and watch them pick up the 45 deg. angle gauge and place it on your intake valve. ;-)
Old 05-30-2024, 10:29 PM   #93
My Citation HO 2.8 came stock with 5 angles..That made tech nuts, for sure, at that time
Old 05-31-2024, 06:42 AM   #94
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Quite confusing but I believe it's any valve angle allowed.
Old 05-31-2024, 07:39 AM   #95
Billy Nees
Glenn, I'm thinking the same way that you are (I guess that I can throw away a set of Aardvark heads). The online rules specifically says "VALVES must retain original valve angle +/- 1*. It does however say ANY valve job is legal which I will Assume (NHRA likes to keep us Assuming) goes to seat angles.
I think that I'll start a thread in the tech section. This needs to be discussed.
Old 05-31-2024, 11:27 AM   #96
B/S 428
Liked 154 Times in 34 Posts
JMO the valve angle +or- they're talking about is the angle of the valve guide and any valve job means any valve job. Brian Seaberg 627
B/S 428 is offline   Reply With Quote
Old 05-31-2024, 11:49 AM   #97
Here's a new interpretation, but I don't think so, Brian.
First of all, how would they check the guide angle?
Have you ever been through a tear down where they actually gauge the valve head sealing angle built into the valve? I have been..Many times, and that used to be what that phrase meant.
Today? Who knows?
Old 05-31-2024, 12:09 PM   #98
B/S 428
Today? Who knows?
Well Ive been through teardown 3x at Indy and pulled valves if that means anything..
Old 05-31-2024, 12:28 PM   #99
And then? Did they check the sealing face angle of the valve...any one of those three times
Old 05-31-2024, 12:38 PM   #100
B/S 428
Mark, no disrespect intended, please read the rulebook, it says any valve job allowed so they don't check valve angles that I know of..my apologies for taking over this thead, I'd much rather talk about the 79 mustang build..
