Old 01-29-2025, 04:08 PM   #1
Lyn Smith
Liked 997 Times in 201 Posts
Default No oil to rockers?
Purchased a set of Comp hydraulic lifters and it is now getting some oil to the rockers. The difference between the two lifters is that the side oil hole is just a little higher on Comp parts. Thanks to all that sent suggestions.
Old 01-29-2025, 04:38 PM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: No oil to rockers?
Wrong lifters? Spinning the drill CCW instead of CW?
Old 01-29-2025, 04:40 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Rotate the crank. Also what drill? typically need a good 1/2” electric drill
Old 01-29-2025, 05:14 PM   #4
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Originally Posted by Lyn Smith View Post
Have a 283 street engine in my 63 Nova cruiser. Just changed the cam and lifters and I'm getting no oil to the rockers. Have tried priming it multiple times. Usually even if you don't get a steady stream out of the push rods you will get a few bubbles when priming with the drill and dummy distributor. Have the engine on my run in stand. Have started the engine and run it for 30 seconds. Has 60lbs oil pressure but no oil to the pushrods. Any ideas?
Originally Posted by 1320racer View Post
Rotate the crank. Also what drill? typically need a good 1/2? electric drill
Stan
Old 01-29-2025, 05:22 PM   #5
1320racer
1320racer's Avatar
He editted his original post 7 minutes after my reply adding that Info dumbazz
Old 01-29-2025, 05:50 PM   #6
1legjerry
Liked 72 Times in 15 Posts
If all you did was change cam and lifters(nothing else) then I would say you got the wrong lifters. What year 283?
Have some work the drill and then turn the crank by hand at the same time.
1legjerry is offline   Reply With Quote
Old 01-29-2025, 06:00 PM   #7
1320racer
1320racer's Avatar
1legjerry…KNOWS
Old 01-29-2025, 07:07 PM   #8
Kenney Kelley
Liked 72 Times in 36 Posts
Does your cam have the notch at the rear journal or does all Chevrolet cams have that? Did you by any chance put the 6 plugs in the block to far? When you primed the block did you remove the 1/8" pipe plug in front of the block to see if you are getting oil up front, if so it might be what the other Gentlemen have said about the lifters or have you run a wire down through the push rods? I know this is basic knowledge and I know you probably have built alot of Chevy Motors in your life time but you were asking for suggestions.
Kenney Kelley is offline   Reply With Quote
Old 01-29-2025, 08:16 PM   #9
Barry Polley
Guest
Posts: n/a
Remove the intake, prime it, does the oil exit bottom of the lifter heavily? If so the lifter is wrong .
Old 01-30-2025, 08:45 AM   #10
curtis reed
Liked 125 Times in 59 Posts
This may sound crazy but I have seen it. Did you look at the lifters to make sure they all have the oil hole drilled in the band?
curtis reed is offline   Reply With Quote
