Old 03-27-2025, 06:17 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default SBC main bearing/spacers
small journal going into large journal block....where can i find them? tks
Old 03-27-2025, 08:27 PM   #2
Randy Wells
Liked 1,144 Times in 354 Posts
Default Re: SBC main bearing/spacers
Use to run king spacers in the 67 302 car, not sure they still make them.
Randy Wells
I/S 5628
Randy Wells is offline   Reply With Quote
Old 03-27-2025, 08:45 PM   #3
nolongerracing
Liked 72 Times in 27 Posts
Race Engineering out of Florida was the last ones to make them. I believe they stopped because of a large run of spacers that where not sized correctly. They were useable with a little extra work. They may still have some of those on the shelf.
nolongerracing is offline   Reply With Quote
Old 03-27-2025, 08:50 PM   #4
BillK
Liked 30 Times in 17 Posts
Clevite still makes the complete thicker bearing so you dont have to use spacers.
https://www.summitracing.com/parts/cle-ms1110h
Bill Koustenis
BillK is offline   Reply With Quote
Old 03-27-2025, 09:04 PM   #5
nolongerracing
Only works if your crank is standard journal size.
Old 03-27-2025, 09:42 PM   #6
mnmaxwedge
Liked 172 Times in 53 Posts
5620 Comp Cams still available. I think they are made by King but I don't recall the King number.
Sorry, that was for large journal mains to 400 mains. I'll check on lg journal to small journal.
mnmaxwedge is offline   Reply With Quote
Old 03-27-2025, 10:06 PM   #7
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
Radar has some spacers
Dom
chopperloco is offline   Reply With Quote
Old 03-28-2025, 06:50 PM   #8
1legjerry
Liked 72 Times in 15 Posts
https://raceeng.com/race-engineering...ck-set-bs-327/
or
https://akerlychilds.com/
1legjerry is offline   Reply With Quote
Old 03-29-2025, 08:39 PM   #9
mfracer
Liked 6 Times in 4 Posts
I have a NEW set of Clevite MS1110H-1 for 283 main into 350 main block
Mike
mfracer is offline   Reply With Quote
Old 03-31-2025, 05:41 PM   #10
richie 2
yes indeed they have them, separate spacer and use whichever bearing you wish. perfect ! now to find a sj rear main seal adaptor...thankyou for the help !
