Liked 5 Times in 3 Posts
Dose anyone make a copper exhaust gasket 4 an olds?
Liked 1,880 Times in 422 Posts
Greg, have you looked at the Cometic website? They may have an MLS style exhaust gasket. I didn't have the greatest luck with those embossed copper gaskets, on anything. I'll tell you what did work though. I used the Mr. Gasket Ultra Seals, and I sprayed them with that dry film moly spray. I've been using that stuff on good gaskets, they don't stick, and you can reuse them a few times.
Alan Roehrich 212A G/S |
Liked 112 Times in 31 Posts
Greg,
Mr. Gasket #7170 from. Also available in aluminum; #7170A. The seal depends on your header flange. Ours work just fine (over & over), and are far superior to the Ultra-Seals which burn out the middle of the center ports. Jerry |
That's why I was asking...went to put the new headders on & both sides had the middle burned out! It was Dads idea to go with a copper gasket. THANKS 4 the help guys!
Greg Fulk 308 308X P/SA "ALL AMERICAN" Last edited by greg fulk; 02-02-2009 at 09:50 PM. Reason: add p.s. |
Liked 10 Times in 7 Posts
Greg try MAXX Performance #170 solid copper exhaust gaskets.
Liked 54 Times in 27 Posts
Another option is Remflex, some sort of graphite fiber, supposed to seal well and hold up.
