Old 10-02-2010, 10:35 PM   #11
Stephen Hughes
Default Re: need help with 60' times
What kind of stop do you have? On my car I was chasing inconsistent 60' times that would swing about as much as yours. I run an inline stop and it turned out the air cylinder was sticking when it would drop on the stop. So one time it would stick a little as it dropped and the 60 would be way fast, next time it wouldn't stick and it would be way slow.
Stephen Hughes is offline   Reply With Quote
Old 10-05-2010, 02:36 PM   #12
pro318
i'm running a inline stop to. how did you figure out that it was sticking. and what was the fix? thanks for the replys guys. was out this weekend trying the shift on time thing, no luck with that.
pro318 is offline   Reply With Quote
Old 10-06-2010, 10:30 AM   #13
SuperCompDiv3
Define "No Luck"
SuperCompDiv3 is offline   Reply With Quote
Old 10-06-2010, 12:04 PM   #14
Chris Williams
Chris Williams's Avatar
Originally Posted by SuperCompDiv3 View Post
Define "No Luck"
Really. Show me a successful .90 racer who shifts on RPM... I don't know any.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 10-06-2010, 02:33 PM   #15
Charlie Yannetti
Liked 192 Times in 83 Posts
Come on now, Chris.. I shift on RPM and my car is very consistent to the 1000 ft.. it's from there to the stripe that I begin to think too much.. and the "GOTTA TAKE THE STRIPE" syndrome kicks in.. but maybe I'm just lucky...
Charlie Yannetti is offline   Reply With Quote
Old 10-06-2010, 02:36 PM   #16
Chris Williams
But I don't know you
Seriously, though, I know a half-dozen people who've tried it (including me), and the tradeoff in getting into the HP band isn't worth the randomness of the climbing of the RPMs when on the stop. Everyone I know is shifting earlier and earlier, we're down to 1.0 seconds, and I know a bunch of people who run in second the whole 1320.
Old 11-06-2010, 04:12 AM   #17
don R
If you shift on time you may need to leave the rpm up around 4300. There was a good article on Biondo's site about setting up a stop.
don R is offline   Reply With Quote
Old 11-06-2010, 08:51 AM   #18
TERMITE S/G 2122
Liked 9 Times in 6 Posts
One thing I found was a break caliper sticking,thats one thing that took me a while to find. Make sure your car rolls easy,and free. Line locks and a sticky break caliper,will for a fact make 60's jump all over the place. Theres always 100's of reason,and it turns out to be ONE that someone on this site will have had. LOTS of good information on this sight and I thank you all for it.
TERMITE S/G 2122 is offline   Reply With Quote
Old 11-06-2010, 10:27 PM   #19
Dick Butler
Liked 32 Times in 19 Posts
No one asked about 4 link? Ladder bar settings? Rigid wall tires versus soft? If the going up on air helps that would tell some info.
