What type are you using and where are you mounting it in a door car. I'm struggling with an inconspicuous clean looking place to mount it and also a place that won't potentially put fluid in front of the tires if happened to overflow.
'67 Camaro 1.25 5.77 @ 118 |
Liked 759 Times in 379 Posts
Never used/needed one.
If you're puking fluid, you're got a problem that needs to be fixed not catched. |
Liked 531 Times in 143 Posts
If you are not puking or leaking fluid out of a racing transmission just means you haven't put any in yet.
It's not currently puking and never has. The vent under the shield has been plugged and a new vent tapped in the rear portion of the case. That's a much lower place on the trans and it has been recommended to me to put a catch can on it. This is a new setup and I don't want to put fluid down and learn the hard way. Just being proactive.
I put mine on the firewall on the passenger side. Any fluid that might make it up there drains back slowly.
#6 | |
Do as you wish with your car, might want to install a parachute too. ![]() Last edited by 1320racer; 04-30-2012 at 09:15 PM. |
That's a mystery and I don't have any clues but am doing what has been recommended since the vent is in that location.
be careful of who you listen to, there's no reason to be plugging the stock vent and relocating it on your trans!
Liked 16,560 Times in 1,523 Posts
40Coupe,
I use one on my stocker. I run line from the factory vent to the trunk. I can access it easy and it has a long line to drain back. I have never had and issues with my C6, but the C4 always left a little in the can when hot lapping. You can run a line tight to the tunnel and back into the trunk for a clean look. I use a polished aluminum can with a breather, looks nice and its out of the way. |
That would be a good problem to have. That would mean I tripped 150 MPH in the 1/4, a really good problem. LOL
