#21 | |
Liked 184 Times in 113 Posts
Yes the 58 got the X-frame as GM began installing heavier engines. GM always boosted about the ride quality. The Lower Links were angled toward the X-Frame and no Panhard Bar. This frame required 2 - short drive shafts and a Center Link prone to snapping. (I know that so well) 65 - 76 went to H - Frame 4 Link set up with Panhard Bar. Spring set on the Lower Suspension Link. Used much heavier U-joints. Then 77 up to 96 D / B Body used the earlier 1964 & up Chevelle/BOP Mid sized car H-Frame set up. Upper Control Arms were angled eliminating the Panhard Bar. Spring mounted on the Axle. The 91-96 used a 8.5inch 10bolt that has a history of being very rugged. Someone said you can put a larger 8.75 12 bolt Carrier in it. Never understood why they were not put in Camaro/FB? The Drive shaft rarely had any issues. U-Joints lasted the life of the car regardless of abuse. For racing gears just needed a balancing and the weight tab removed from the Yoke...and still keeping the original U-joints. On my 1995 Impala SS purchased a Dick Miller Frame Connector for the upper and lower control arms. Think he makes it for the Plus Sized cars too. Hope this helps.. D |
#22 |
Liked 53 Times in 16 Posts
Hey Joe, good hearing from you. Yes, Carl is taking pictures and video. I will be posting a new pic next week of the rear frame gusseting work. Only way to make these boats survive!
Rob has the motor in South Carolina with the 1976 Ford F100 truck i bought down there. He has been using the truck w/ the new house. Don't know if I can use it as a tow vehicle, being a Ford and all!! LOL Dan, the lightest I had the 68 was a the minimum H/S weight or 3950. I added a 135 pound bar to the back to make I/S ! If you want i can e-mail you a pic of the rear work I did on the car so you can show your chassis man. Will Lamprecht "Tuns of Fun" !! 65 Impala |
#23 |
Hey Joe, Sorry I made that comment about the Nova you and Ed ran never getting it to run like Billy Nees Nova. It was still a sweet ride and built right by you guys.
I also run into Ann's brother Eddie all the time now, at the meetings. so what do you think? "Tuns of Fun" on the side? Will Lamprecht |
#24 | |
use danfahey@dansources.com |
#25 |
Liked 105 Times in 26 Posts
I'm diggin' this!!!!!
#26 | |
65-70 full size ..3 or 4 arm (right or both uppers). Panhard bar, and springs on trailing arms. 71-76 ..Std 4 trailing arm, springs on housing , except for f/s wagons ,which were leaf springs. 77-96 Std 4 trailing arms ....7.5 rear standard in these cars... even in f/s Chevy wagons.
#27 | |
Liked 8 Times in 7 Posts
without losers,winning means nothing. |
#28 | |
Have them on both my 94 Caprice Wagon an 95 Impala SS The Camaro/FB got the little ones D |
#29 | |
305's came with 7.5's ...I had one...with a 2.56 That gives you about a 1.80 gear in OD..That's how it got 28 mpg @70 with the a/c on.
#30 |
Liked 783 Times in 195 Posts
Yac -
My parents had an '86 Caprice 305 that came with a 2.29:1 7.5 rear axle. I drove them to the east coast to see my brother when that car was relatively new and it got 25-26 mpg @ 70 with A/C on consistently using an electronic Qjet carb! Amazing considering the aerodynamics of that body. |
