Old 06-30-2013, 01:44 PM   #21
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: 1965 Impala BBC I/S
Originally Posted by Tom keedle View Post
for some reason i remember 65-70 fullsize chevies having a 3 link (2 on the bottom,1 on top) on the base models with small blocks....or am i just dreaming?
seems to me the 4 links were the higher HP models...
That was the X - Frame 1958 - 1964 Chevy/BOP/Caddy
Yes the 58 got the X-frame as GM began installing heavier engines.
GM always boosted about the ride quality.
The Lower Links were angled toward the X-Frame and no Panhard Bar.
This frame required 2 - short drive shafts and a Center Link prone to snapping. (I know that so well)
65 - 76 went to H - Frame 4 Link set up with Panhard Bar.
Spring set on the Lower Suspension Link.
Used much heavier U-joints.
Then 77 up to 96 D / B Body used the earlier 1964 & up Chevelle/BOP Mid sized car H-Frame set up.
Upper Control Arms were angled eliminating the Panhard Bar.
Spring mounted on the Axle.
The 91-96 used a 8.5inch 10bolt that has a history of being very rugged.
Someone said you can put a larger 8.75 12 bolt Carrier in it.
Never understood why they were not put in Camaro/FB?
The Drive shaft rarely had any issues.
U-Joints lasted the life of the car regardless of abuse.
For racing gears just needed a balancing and the weight tab removed from the Yoke...and still keeping the original U-joints.
On my 1995 Impala SS purchased a Dick Miller Frame Connector for the upper and lower control arms.
Think he makes it for the Plus Sized cars too.
Hope this helps..
D
Old 06-30-2013, 06:28 PM   #22
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Hey Joe, good hearing from you. Yes, Carl is taking pictures and video. I will be posting a new pic next week of the rear frame gusseting work. Only way to make these boats survive!
Rob has the motor in South Carolina with the 1976 Ford F100 truck i bought down there. He has been using the truck w/ the new house. Don't know if I can use it as a tow vehicle, being a Ford and all!! LOL
Dan, the lightest I had the 68 was a the minimum H/S weight or 3950. I added a 135 pound bar to the back to make I/S ! If you want i can e-mail you a pic of the rear work I did on the car so you can show your chassis man.
Will Lamprecht
"Tuns of Fun" !! 65 Impala
Old 06-30-2013, 06:34 PM   #23
impstocker
impstocker's Avatar
Hey Joe, Sorry I made that comment about the Nova you and Ed ran never getting it to run like Billy Nees Nova. It was still a sweet ride and built right by you guys.
I also run into Ann's brother Eddie all the time now, at the meetings.
so what do you think? "Tuns of Fun" on the side?
Will Lamprecht
Old 06-30-2013, 06:48 PM   #24
Dan Fahey
Dan Fahey's Avatar
Will Lamprecht
YES PLEASE
use danfahey@dansources.com
Old 06-30-2013, 07:53 PM   #25
Shaun Quill
Liked 105 Times in 26 Posts
I'm diggin' this!!!!!
Old 06-30-2013, 08:25 PM   #26
Hope this helps..
D
For the record:
65-70 full size ..3 or 4 arm (right or both uppers). Panhard bar, and springs on trailing arms.
71-76 ..Std 4 trailing arm, springs on housing , except for f/s wagons ,which were leaf springs.
77-96 Std 4 trailing arms ....7.5 rear standard in these cars... even in f/s Chevy wagons.
Old 07-01-2013, 05:33 AM   #27
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
For the record:
ahhh, so i'm NOT crazy (even though my mother had me tested )
Old 07-01-2013, 04:41 PM   #28
Dan Fahey
Dan Fahey's Avatar
For the record:
91-96 all got the 8.5 inch Rear, at least the 5.7 liter.
Have them on both my 94 Caprice Wagon an 95 Impala SS
The Camaro/FB got the little ones
D
Old 07-01-2013, 06:37 PM   #29
D
Nope....you didn't say 5.7 cars, which may be true.
305's came with 7.5's ...I had one...with a 2.56
That gives you about a 1.80 gear in OD..That's how it got 28 mpg @70 with the a/c on.
Old 07-02-2013, 06:39 AM   #30
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Yac -
My parents had an '86 Caprice 305 that came with a 2.29:1 7.5 rear axle. I drove them to the east coast to see my brother when that car was relatively new and it got 25-26 mpg @ 70 with A/C on consistently using an electronic Qjet carb! Amazing considering the aerodynamics of that body.
