Old 02-14-2014, 08:32 PM   #21
Ed Wright
Ed Wright's Avatar
Default Re: Differential heater
Originally Posted by art leong View Post
Bill I know of some 1400 HP FWD cars that use ATF in their differentials They have a 170 plus trap speed.
Could be the gears are cut differently (Not Hypoid?). But they use it I know.
Think load from car weight could be part of it too?
Ed Wright 4156 SS/JA
Old 02-14-2014, 09:14 PM   #22
Bill Edgeworth
Yes, just equates back to pressure on the gear face. And what Art mentioned how the gears are cut can affect both how much the gears must actually slide against each other and the actual amount of contact area they have. As for a 1400 hp FWD car using ATF could it be due to necessity as the transmission and differential share the same oil?
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 02-14-2014, 10:06 PM   #23
art leong
Ed I'm pretty sure the way the gears are cut for a RWD application is the difference. Our ring and pinions make contact in a completely different area.
Art Leong 2095 SS
Old 02-14-2014, 10:08 PM   #24
art leong
Yes they share the same oil.
Art Leong 2095 SS
Old 02-15-2014, 11:34 AM   #25
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
I have a bunch of free Valvoline 75/140 synthetic gear lube that I would like to try. We have a Dana 60 and have had 0 problems in 9 years of hard racing so I'm afraid to change anything. What do you guys think? Just looking for consistency. We now use 80/90 conventional.
Old 04-03-2014, 05:50 PM   #26
Damn Yankee
Originally Posted by gsa612 View Post
A few years back I went to a T&T, drained out the RP and put in the JG.My buddy brought his car we made a pass together he lost a hun.from his previous run (DA was the same) and I picked up 2.I left it in for another few races. I know some guys run it in B&C cars (12 bolt).Mine is a 10 bolt btw. gsa612
gsa, which JG oil were you using for your differential? I was looking at their website and they list the L9 thru L11, the L11 being their qualifying oil which they say can be used for short periods of time.
Damn Yankee is offline   Reply With Quote
Old 04-03-2014, 06:06 PM   #27
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
I use it in my Dana and the gears last literally for ever. I am sure I get way over 1000 runs and have never had one fail with the auto trans. I did try some lighter oil and the gear wore out fast. No improvement in ET with the lighter oil so I went back to the Valvoline synthetic.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 04-04-2014, 09:22 PM   #28
randy wilson
Liked 22 Times in 22 Posts
I don't know if what I do works or not, but it makes me feel good about it. Here goes. I run 1\2 quart synthetic auto trans fluid, 1\2 quart 50 wt. synthetic racing motor oil, and 1 quart synthetic 80\90 gear lube. We put over 100 runs on a 6.20 gear before changing gears. Mostly 1\8th mile. A stick car leaving at 9,200, weighing 3040 lbs. The only thing I see that's changed is we used to get about 150, to 170 runs on a nodular center section then an aluminum through bolt. Anyone ran into that? Makes me wonder if the nodular might actually take less drag because of distortion. I never run it low.
don,t have one
