Liked 216 Times in 77 Posts
On a TH350. If you were to kill the engine after the finish line and then put it in neutral would it hurt the transmission? I know unless you have clean neutral you cannot just shift it to neutral or it will do damage. What I am wondering is since the output shaft is still turning but the pump would not be would damage it.
Thanks Rob |
#2 | |
Ed Wright 4156 SS/JA |
What about Killing the engine but leaving it in gear? Or would that do the same thing as going to neutral with engine running?
Don't know about that one. I wouldn't do that myself. What Carl Rossler told me when I messed mine up was "Multiply your engine RPM by your first gear ratio, that is how fast that drum spins up to when you put in neutral in the lights."
#5 | |
Liked 172 Times in 81 Posts
Jim Mantle V/SA 6632 |
Liked 19 Times in 7 Posts
TCI and Turbo Action forward pattern valve bodys can be nutraled and does not hold the clutches on. I just changed over from TCI to TA and called and asked if i could nutral it and the answer was absoutely yes.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Rossler has that as well as ProTrans. My Rossler was bought used, and did not have "clean neutral".
