Old 03-08-2015, 07:20 PM   #271
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: Woodfin's SS GT/TB construction series
Goodness, does that engine have room to breath. Gotta love that.
Enjoying seeing your build.
SSGT Mustang is offline   Reply With Quote
Old 03-10-2015, 03:40 PM   #272
Dragsinger
Liked 99 Times in 60 Posts
Today's construction, a "Just In Time" switch mounting bracket. Shown here in rough/under development form.
The material is 12 gauge sheet [1/16"] light, easy and ridged.
ID:	27853   Click image for larger version
ID:	27854   Click image for larger version
ID:	27856   Click image for larger version
Larry Woodfin 471W
Old 03-11-2015, 06:43 PM   #273
Dragsinger
I "fret" over things! Especially items that are giving me trouble because I am having problems visualizing the details.
Example, engine placement in the Super 10. Because S-10 trucks never came equipped with SBC engines nor 12 bolt rear axles, nor 32 x 14 rear tires it is a challenge to juggle the driveline alignment.
So, after some "fishing lessons" from an experienced friend, I did just like a full tube chassis would be aligned.
I used a full length mandrel [also known as a section of 2 1/2" tubing] through all main caps all the way to the pinion flange.
Photo #1 shows mandrel aligned with pinion [camera angle is mis-leading, it is spot on aligned]
Photo #3 show mandrel out rear of block
Photo #4 shows mandrel out front main
When finalized the pinion will be adjusted about 1.5* down
I like it when a plan comes together
ID:	27863   Click image for larger version
ID:	27864   Click image for larger version
Larry Woodfin 471W
Old 03-11-2015, 07:08 PM   #274
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Your doing a 'Marvelous' job Larry, .......... it's looking GOOD !
Old 03-12-2015, 08:07 PM   #275
Dragsinger
We have two more photos of the "Just In Time" switch mounting. The photos are not a true representation of the position. It is just right for gettin all over the bottom bulb
Being satisfied with the positioning it comes out for cleanup and paint.
Also note the instrument readings
ID:	27869   Click image for larger version
Larry Woodfin 471W
Old 03-12-2015, 08:12 PM   #276
Dragsinger
and two more photos of motor plate fitment.
The small circle inside the alignment tubing is the pinion nut shot from the front main.
ID:	27871   Click image for larger version
ID:	27872   Click image for larger version
Larry Woodfin 471W
Old 03-13-2015, 01:00 AM   #277
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Cool...zero mileage.
Rich Taylor
I/SA - 321
Old 03-13-2015, 03:36 AM   #278
Dragsinger
Yes, with factory break in oil
Larry Woodfin 471W
Old 03-22-2015, 02:20 PM   #279
Dragsinger
It gives me a smile when parts go in for the final time. This shows the bed cleaned and painted [well, almost, mid floor will be in soon]
Battery, cell, compressor, fuel pump ready to bolt down. Also, some of the wiring roughed in and in process.
Third photo shows becoming satisfied with front plate placement. Mounting tab patterns attached with vice grips.
ID:	27976   Click image for larger version
ID:	27977   Click image for larger version
Larry Woodfin 471W
Old 03-22-2015, 07:45 PM   #280
Dragsinger
This will be an interesting week for the Super 10. I am submitting the information to Micheal Beard to finish the design work.
Once Michael has the final design I will post the results. The design will incorporate our "Team Woodfin" logo, the "Super 10" logo and other special licks.
The truck bed will have a white aluminum cover. On that cover will be;
"Faster Than A Bullet"
"More Powerful Than A Locomotive"
"Able To Leap Tall Buildings"
[then the Super 10 logo]
Larry Woodfin 471W
