Old 06-14-2015, 08:29 PM   #331
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Under the index for under a grand!
OK, you asked for it! Mull over these for a while.
Right click
save image
Dave Noll, EF/S ,?/SA 6526
Old 06-14-2015, 09:36 PM   #332
Dave Gantz
Liked 251 Times in 125 Posts
You ain't kidding'!
Old 06-15-2015, 07:56 AM   #333
Bunkster
Liked 43 Times in 10 Posts
Originally Posted by HandOverFist View Post
Years ago, VSI (valve spring insert) had a similar wall poster. A valve was chasing a spring, with the spring exclaiming "No, no...not without a VSI"
Bunkster is offline   Reply With Quote
Old 06-15-2015, 05:23 PM   #334
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
WOW..
After you get this done Billy....for under a $1000...
Now what would it cost to set a National Record?
Dan
Old 06-15-2015, 05:49 PM   #335
Billy Nees
Now what would it cost to set a National Record?Dan
Ain't happening, Dan! Though I would never discourage anybody from setting a National Record, I've been there and done that and until NHRA decides to reward me for doing so (which they should), I don't need the EGO boost. A piece of paper and my name in the back of Dragster(so small that you need a magnifying glass to see it) just isn't reward enough. Besides, the person who wins class at Indy should be the Record Holder because that person is the "hitter" in the class.
Billy Nees 1188 STK, SS
Old 06-15-2015, 06:22 PM   #336
Billy Nees
Dan, just for the (National) Record, if I were starting with a clean sheet, I would be building an "Under The Index for Under a Grand" using some kind of FFFord with a 302 2V in it. That could easily be an "Under the Record for Under 5 Grand" build.
Old 06-15-2015, 07:12 PM   #337
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Things of beauty - I'm so jealous! Any chance on getting the dimensions?
Mike Moller
NHRA 203 Q-R-T/SA
Old 06-16-2015, 01:05 PM   #338
Dan Fahey
Dan Fahey's Avatar
Good Point !
My Pure Stocker is always in development.
Just never set a Record so it would be a goal for me.
Have an opportunity to set 1/4 F/PS since it is wide open.
Just in D1 will have to be under hot weather conditions.
Got a nice Featherlight trailer and stopped driving to the races.
Now can tear down and make it back home.
Fixed up the 94 Caprice wagon to tow everything.
New trans, beefed up rear suspension, gears.
Installed a rear sway bar and for its weight will do well in Autocross.
Good to build a competitive racer for under a $1000.
Seems you cannot tow safely for "under" A LOT of money.
Dan
Old 06-17-2015, 08:11 AM   #339
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Billy, I wonder what would happen if NHRA would reduce power factors on '70s 2-bbl engines of ALL manufacturers to the OEM hp rating? Since the majority of racers are GM fans, there has not been the mad rush to the 302 2-bbl combos like I thought there would be, but I will not comment more about that. There were as many '86 Chevy trucks built as 302 2-bbl Fords, if that is a statistic to ponder.
Of course, with NHRA's worshipping of the AHFS, something like that would never happen. Where's the fun?
Old 06-17-2015, 09:48 AM   #340
Billy Nees
Dwight, this sounds like a good subject for it's own thread. I think that you have an excellent idea there for helping "underprivileged" and "entry level" racers get going. NHRA would have to rework it's AHFS to make it more reactive to the combos that wind up being accidently too soft though. A year between reviews is too long.
