Old 05-07-2018, 06:05 AM   #11
Painter
Liked 162 Times in 45 Posts
Default Re: Trsiler Tiers OR Light Truck?
My last two trailers came with goodyear's. They said they were good trailer tires. After changing way too many and replacing both fenders on the last trailer I will not buy anything g Goodyear that they say is good. They said the marathons were good. We all know how that worked out. And the G159 motorhome tires. I have my doubts about goodyear right now.
Painter is offline   Reply With Quote
Old 05-07-2018, 07:03 AM   #12
SGSST109E
Liked 126 Times in 61 Posts
If your raise the trailer so the tires are off the ground in the off season you will see an increase in tire life wether LT or trailer tires. In the NE our off season is 6 months long. I used to put the trailer on jack stands now I use trailer legs, much easier. Prior to getting the tires off the ground every 3 to 4 years the tires would blow out.
SGSST109E is offline   Reply With Quote
Old 05-07-2018, 08:50 AM   #13
Pistol Pete
Pistol Pete's Avatar
Liked 811 Times in 213 Posts
Originally Posted by Painter View Post
I have been using and having good luck with Maxis load range E on our three axle 32 footer. But just found out yesterday that Hercules is offering a load range F very soon. The load range is carrys more air and should be a better tire for the way we use them.
I also had the Maxis 15" tire on my trailer, load range E.
That was a very good tire.
Main thing during the season if it sits outside is to cover them & Always check your
tire pressure before going to the next race.
And Great advice by Tom Goldman with the valve stems.
"Pistol" Pete Dutko
Old 05-07-2018, 10:30 AM   #14
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
and stay away from carlisles....
Old 05-07-2018, 11:13 AM   #15
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
OK after two Blow Outs ... !
Who makes the best trailer trailers tires other than Goodyear..
Looks like they are a great tire and the most expensive.
My wagon for towing uses Nitto's as they have a load ratings 250 lbs better than any other tires.
Dan
Old 05-07-2018, 01:12 PM   #16
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Dan
$128 a tire is hardly expensive if you factor the cost of damage from a blow out or worse if you loose control !
Tom Goldman is online now   Reply With Quote
Old 05-07-2018, 01:37 PM   #17
Dan Fahey
Dan Fahey's Avatar
That was not my point..
The most expensive does not mean it is best.
Old 05-07-2018, 01:38 PM   #18
Dave Casey
Liked 804 Times in 168 Posts
Dan
What was the brand and age of the 2 blowouts ?
Dave Casey 1330 STK
Old 05-07-2018, 01:46 PM   #19
Dave Casey
My Daughter and Son in Law paid 105 each for 235/15's delivered (GY Endurance)
Dave Casey 1330 STK
Old 05-07-2018, 02:50 PM   #20
jmcarter
jmcarter's Avatar
Liked 3,230 Times in 982 Posts
Tire Rack?
After blow outs on my Motorhome (G670's and FYI the G159 tires referenced by Painter are subject of a big class action suit) and exploding Goodyear Marathons on the trailer (replaced with Maxis Load Range E with great results) I'm a little gun shy of GY but have to admit the Endurance are getting good reviews. If you have Marathons on your trailer you are tempting fate.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
