Old 05-18-2018, 12:51 PM   #1
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Default Class Racer Info
Using the very helpful site that Dwight has provided, I have a question regarding piston compression height. As an example one of the listed repl. pistons for a 1969 Chevy 350/300 is the TRW L2256F. TRW lists the compression height @ 1.563 " however the NHRA tech spec is 1.535". I am missing something ?
Old 05-18-2018, 02:37 PM   #2
Race Clean
Liked 129 Times in 53 Posts
Default Re: Class Racer Info
No,only that you are good by .002 on that part of the side
You can still get the desired Deck clearance!
Race Clean is offline   Reply With Quote
Old 05-21-2018, 04:56 PM   #3
jmantle
Liked 172 Times in 81 Posts
NHRA lists the minimum accepted pin height. Most replacement pistons will exceed this dimension but still give you room to deck the block.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
