#581 |
Liked 33 Times in 16 Posts
If that is the actual case and was called on it I would just go with the swing-out bar myself...makes all the difference in the world getting in and out of many of these cars. Those high side bolsters on the aluminum seats compound the problem.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 08-20-2018 at 09:26 PM. |
#582 |
Thank you. And which one did you use?
Todd Greene |
#583 |
Liked 162 Times in 45 Posts
I am a long way from the car, but knowing me it was the cheapest!
#584 |
Haha gotcha thanks.
Todd Greene |
#585 |
Liked 692 Times in 205 Posts
Todd the car is a piece of art. Attention to detail is breath taking.
#586 |
Thanks Nick, Much appreciated. It's been a great ride so far. The real fun will be next year when we see how good we are at making this thing haul *****!
Todd Greene |
#587 |
Been a rough week at work so far and I haven't gotten anything done. Autumn has been running parts around after school and I finally got in the shop for a couple hours today. Made the last ground strap, the starter cable, and it actually turned over for a second so that works. Started working on the brake pressure gauge so I can get the last flex hose made this week to button up the brake system.
Todd Greene |
#588 |
How does a 20 minute job take 3 hours! My wife simply calls it... car time.
![]() ![]() Made a thread chase to work on the wheel stud threads, got them all straightened out. Put a new set of studs in and finally got the rear back together. Brakes are on, brake lines are on, pressure gauge is mounted and plumbed too. We started to run the fuel lines for the final time too. Autumn worked on the tank brackets and of coarse drilling and tapping the radiator for no other reason than why not change EVERYTHING since that is our current theme. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Todd Greene |
#589 |
Liked 196 Times in 29 Posts
Hey Todd,
When you do it RIGHT the first time, you will never have to touch it again, no matter what the project is. Obviously, you and your daughter are doing it RIGHT..... Congrats on the build, it is Very Special!!!! Gary Merrick 3522 Stock |
#590 |
Thank you Gary.
Todd Greene |
