#1401 | |
Todd Greene |
#1402 |
Liked 544 Times in 213 Posts
Yes Todd I would assume all those parts were made and machined to fit together and work properly.
Will be interesting to hear what feedback you get from Diamond.
#1403 |
Got the heads apart today #3 chamber took a nasty hit. Have a few bent valves so I'll order a whole new set tomorrow and hope we have room to surface the head into good working order. Diamond has reviewed the pistons and believes there's a problem with the way the groove was machined, they're investigating further but in the meantime they'll expedite a set and get them out at no charge. Still waiting to hear back from Titan about oil pump fitment but I believe I'm going to cut my junk pan up and take some measurements.
Todd Greene |
#1404 |
Liked 254 Times in 78 Posts
Todd,
Make sure you check that head for cracks. If they have been milled quite a bit to get the right cc's they can crack easily from a piston or valve hit.
Mike Moller NHRA 203 Q-R-T/SA |
#1405 |
I'll be pressure testing the head, I'll post up some pictures of the process. Should be a new learning experience.
Todd Greene |
#1406 |
Block is here, rods are here. It's groundhog day!
Todd Greene |
#1407 |
Liked 242 Times in 81 Posts
DEJA VU all over again Reading your posts I have learned way more than I ever wanted to know about a Cheby. Wish we could get blocks for our Mopars in 2 days.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#1408 |
I don't know much about a Mopar, and at this point I know more about machine work than I ever wanted to, but yes, Dart really came through with the block. We have plenty of work to do I'm guessing till mid next week.
Todd Greene |
#1409 |
Cams are expensive... That is all.
Todd Greene |
#1410 |
I feel like today was a pretty good one, crank came in, lifters came in and the "cam guy" is on board with my ridiculous schedule. Got all 8 holes bored today and got it on a stand.
Todd Greene |
